Home > Technical (L322) > Navcoder
Ash_vogue
Navcoder
Hi
Does anyone know where I can buy the hardware for navcoder? I know I can get the software from the website but where can I get a USB cable to plug into my laptop/car?
Thank you
Post #198843 14th Jul 2013 10:28pm
http://www.navcoder.com/ Thumbs Up ... - .- -.
Post #198863 15th Jul 2013 8:54am
Reformed
I am sure I still have my usb interface from when I owned my Rangie, if your intrested? I wouldnt ask for much, will see if I can find it. PM me if your interested. Thumbs Up Reformed
Post #198967 15th Jul 2013 8:11pm
kay323
I have a USB one
Post #199454 18th Jul 2013 9:58pm
Ash_vogue
Where did you get that from?
Post #199459 18th Jul 2013 10:11pm
AFAIK, the only way to connect up the PC with navcoder installed on it is to use the Resler USB or Serial interface from here:
http://www.reslers.de/IBUS/index.html
This is what I have in my FFRR:
http://www.fullfatrr.com/forum/post96346.html#96346 .
Post #199499 19th Jul 2013 12:22am
mjdronfield
I got a cable from BMW cables on eBay. It was listed as working with a few bits of software, including navcoder. Came with some cdr's with BMW tis software and Ebas I believe, but I didn't use that. £20 something if I remember right. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #199507 19th Jul 2013 5:07am
kay323
I have the same one as the link above. Where abouts are you based, maybe you can borrow mine if local
Post #199671 20th Jul 2013 2:11am
Ash_vogue
Thanks for the offer, I live in Leicestershire, I don't mind buying one, just want to get one that will work and is easy to use. Is the one from the link above just plug and play?
Post #199771 20th Jul 2013 9:40pm
Winchester101
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
hi kay
do you still have the ibus reader could i ues it if we are close enough
Post #241159 8th Feb 2014 11:05pm
thatgirl101
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
Hi all, just bought a cable from ebay - but where do I connect it?!
Post #262482 31st May 2014 5:13pm
mjdronfield
It goes in the obd2 connector that is in the little compartment near you right knee as you are driving. It's a few inches under the light switch. There is a black cover on it that you will have to pull down.
I have a duster in mine for cleaning the screen. The connector is pointing downwards........
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #262496 31st May 2014 7:30pm
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #262498 31st May 2014 7:38pm
Andy
Good luck with the obd cable. I bought one and I didn't work. I then emailed the navcoder guy and he said not to use the obd port. I ended up buying a serial port version in the end and soldering the cables directly into the can bus line
Post #262835 2nd Jun 2014 8:11pm
Agree with Noddy, from the navcoder site:
Quote:
What you need to use NavCoder
To use NavCoder you need a laptop with Windows (anything from Windows 2000 to Windows 7; it may still work on Win95, but I cannot test it on Win95 any more) and an ibus interface.
The ibus interface is the necessayr hardware interface to convert the electrical signal of the BMW ibus into good old RS232 for the laptop.
You can choose to make your own ibus interface, using the circuit diagram supplied in the NavCoder installation directory. It's simple and cheap, costing much less than USD $10 in parts.
Or you can purchase a "Resler interface" from Rolf Resler. Have a look at Rolf's website. Rolf's ibus interface is available as a USB version or a good old serial com port version. Choose what you want based on what ports your laptop has available.
Both of the "Resler interfaces" are 100% compatible with NavCoder.
http://navcoder.com
As I mentioned above, I have used the resler interface with success. .
Post #262876 3rd Jun 2014 1:14am
