Home > Maintenance & Mods (L322) > Problem with new windscreen |
Well that's a new one thanks for the info |
19th Jul 2013 3:15pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6355 |
I had a look at this, it was truly weird, never seen anything like it.
19th Jul 2013 3:16pm |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
Makes you wonder what "FY" might stand for...
19th Jul 2013 3:23pm |
NKSC Member Since: 09 Nov 2011 Location: Lincs Posts: 156 |
^ I was thinking the same!
19th Jul 2013 3:32pm |
When mine was changed (AA Windscreens) the fitter failed to seat the clips for the sensor pod properly. It caused the autolights to go "off" in the dark. Pretty frightening. Could be the same fault. It took the remediation fitter a couple of minutes to rectify. Graham
19th Jul 2013 3:38pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
I know of an FFRR with the old rain/auto lights sensor stuck onto the replacement screen by the "professional" fitter with sticky pads
19th Jul 2013 3:39pm |
Mine are always on, which in the current weather I didn't notice for about 4 days! I will check all of this when its replaced on Tuesday. |
19th Jul 2013 3:55pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1227 |
I had a similar issue when I had a BMW convertible screen changed. There was a definite magnified ripple in the screen a few inches up from the dash.
19th Jul 2013 6:51pm |
^ Wot he said. Flashman's experience is identical to mine, and it was a BMW as well. Graham
19th Jul 2013 7:23pm |
Finally I had the screen replaced yesterday with a Pilkington screen. This one looks OK but i'm still getting a definite 'wave effect' when I use the heated screen - now i'm begining to wonder whether the original one did the same and i just didn't notice.
7th Aug 2013 11:01am |
You may as well go for the LR replacement and see what the effect is.
7th Aug 2013 11:15am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34936 |
if you focus on the screen you will see 'wavy lines' to a certain extent but when you look through it to the road etc you wont notice them..i've read that spectacle wearers sometimes have issues because of the difference in polarisation.. ... - .- -.
7th Aug 2013 11:17am |
