Home > General > Air Con Problem
liverpoolphil
United Kingdom 2003 Range Rover HSE Td6 Tonga Green
Air Con Problem
......so the air con stoppped working the other day(been icey cold since I started using it in spring), dropped it in at the local kwik fit for a re-gas and they told me the pressure check showed no leaks but the gas wasnt filling up the systemhey told me the compressor must have either gone or have a hole in it and I need an air con specialist to have a look (apparently they put some UV dye through the system)
Anyone had a similar experience and more importantly can anyone recommend an air con guy (pref rr guy) who can have a look at my car. I am in Ormskirk, Lancs
Post #20029 13th Jun 2010 10:15pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Steve Parkers pretty good, in Whitworth. Google will get u his website. Very Happy
Post #20034 14th Jun 2010 7:14am
liverpoolphil
still on the lookout if anyone can recommend someone in the NW area Thumbs Up
Post #20433 17th Jun 2010 2:29pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
There is a guy I have used around Preston that is good, but not sure how far south he goes.
I know he has been to Southport.
Not sure of his number, as I am at work at the mo. Can PM you it tomorrow, if you want.
Post #20450 17th Jun 2010 8:00pm
liverpoolphil
yeh that would be good thanks Thumbs Up
Post #20467 18th Jun 2010 9:53am
Similar problems
Air con not doing anything cool-wise, so got it regassed at Kwikfit. No reported leaks. Air con worked OK then, although it does switch on and off (fans) bewfore it gets going properly.
Whilst tooling down the motorway yesterday, air con took about 10 minutes from leaving home to get going, then worked for @ 20 mins. then slowly blew cool air. Started to smell a funny smell, then noticed the centre vents were blowing out smoke or vapour. Hit the * button !! Not tried it since. (It was a hot day, @ 28 degrees C, doing 70mph)
Any pointers to what is wrong - compressor? Something in the HEVAC? .
Post #22114 12th Jul 2010 12:22am
