![]() | Home > Maintenance & Mods (L322) > How to disable seatbelt warning on 2010MY? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
The old trick of clicking the seatbelt in and out ten times in 30 seconds doesn't seem to work on my dad's 2010MY car, is there a new way of doing this?
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3805 ![]() ![]() |
As above, Did mine, think the ignition was on, nobody sat in seat and connected and disconnected seat belt till you got the bong - might have been 9 or 10 times 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
I struggled to get this to work on my 2010MY, in the end I used my faultmate |
I tried the 10 times trick the other day but because the car was boxed in I couldn't take it for a spin to see if it had worked, had a message from my Dad saying it HAS worked so thanks chaps for the confirmation, I shall need to do this on my Supercharged when I get it too. Discovery 4 HSE
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 ![]() ![]() ![]() |
I will give his a try later today on my 2012..... how annoying can a constant bong be if oyu only drive along on your own premises..... |
Worked! |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Why would anyone want it turned off? Its law to wear then and foolish not to surely! |
I always wear mind on the road but there's times on shoots, farms, fields etc and you don't need it, a bong is just annoying. Discovery 4 HSE
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
I'm seatbelt exempt through surgery forever now so I got a td5 steel clip and just leave it plugged in all the time, annoying it is tbh the old 03 was fine. _____________________________________________________
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
The 10 times click didn't work on my 2007 Is this where I put the car details and a bit about myself ?........ |
should do Nick, try nine... ... - .- -.
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
It worked on my old MY11 and it even worked on my MY14 L405. |
Car running or just ignition on ? ![]() |
Ignition on only - make sure no weight on the seat cushion and connect and disconnect the seat belt - sure mine made a bong when deactivation was complete 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
