Home > Technical (L322) > changing the battery
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
yes....have read the wiki
and in the pictures, there is only a battery in the battery bay.
I have a MY11, and there are some electrical parts in front of the battery mounted onto the front part of the bay. Any idea what these electrical components do, and thoughts about removing them?
Post #201061 27th Jul 2013 6:40am
could be an auxiliary junction box that receives its main power supply from the battery and provides circuit protection for the glowplug system.... ... - .- -.
Post #201072 27th Jul 2013 8:37am
twhincup
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
can you get a pic? 2007 3.0L Diesel VW Touareg SE
2003 4.4 LPG, Vogue, Silver
Post #201088 27th Jul 2013 10:15am
Rambles
Post #201089 27th Jul 2013 10:21am
Rambles
this photo view is from looking down at the battery....engine bay to the bottom, windscreen to the top
just in case you couldn't see the orientation
Post #201090 27th Jul 2013 10:23am
Just poured over the + 05 manual. No pictures showing this in place.
The item stan referrs to is stated to be fitted "behind" the battery.
The only other thing there was an image of that looks similar is an ECM (same thing ?)
Advise proceed with caution, move out of the way, although once you have disconnected the battery it should be OK to dismantle to gain access. .
Post #201103 27th Jul 2013 11:40am
Rambles
always easy to dismantle...it is the re-assembly !
if you can see on the RH side, there is a red connector switch for the block. there is another one underneath it.
am assuming I just pull the two red levers to disconnect the blocks?
have I got something unusual here on my MY11 - or can other MY11 and MY12 owners confirm if they have the same kit in the battery bay.
i do recall a year or so ago when LR fixed my battery and FBH problems, they told me they had installed a level battery management system.....could this be it?
Post #201206 28th Jul 2013 7:52am
