![]() | Home > Technical (L322) > l322 dropped on the o/s/f |
b20wht Member Since: 08 Apr 2013 Location: lincs Posts: 45 ![]() |
p.s Just looked out the window at the RR and its bloody sunk again on the o/s/f. Is it most likely the airbag? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
probably...stick it in off road and see if it leaks. ... - .- -.
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
As Stan says - it may be that the leak (crack or split) is just above normal ride height on the bag so rises ok to reach normal height. when it extends a bit further towards off road it opens the split and so never makes it fully up. The leak is probably enough to seep out slowly under normal conditions hence it drops eventually.
Yes you are spot on, I did this earlier on today and I can hear it |
