Home > Maintenance & Mods (L322) > Creaking noise
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Creaking noise
I'm getting a creaking noise from the passenger side front wheel (08 tdv8). It sounds like a loud clicking or creaking when turning right. Difficult to describe and I'm going to whip the wheel off tomorrow. Anyone got any ideas what to check and how to check it? My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #201427 29th Jul 2013 9:22pm
Googsy
That happened mine like a squeaky pram sound? It was the lower control arm bush on the front I believe that needed replaced. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #201436 29th Jul 2013 10:17pm
hoppy_70
This one??
http://www.eurocarparts.com/mobile/ecp/c/L...amp;000320 My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #201438 29th Jul 2013 10:39pm
Googsy
Yes that was gone on mine and was cause of squeaking. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #201449 29th Jul 2013 11:43pm
edward.barry
Ireland 2005 Range Rover Vogue Td6 Buckingham Blue
Replaced th 3 times on mine, including anti roll bar link bar, lower suspension arm twice, anti rollbar, front shock and bag, lower ball joint, and still have the crack on turning right and running over undulatin surfaces, frankly have just given up 0-60 takes 5 and a half seconds...and about 17 gallons of fuel....
Current fleet
2005 RR td6
1997 300 Discovery
2005 Subaru Legacy Outback (the wife's)
1981 2.5 Opel Commodore
Post #201626 30th Jul 2013 9:28pm
Googsy
Who do you use Ed to do your servicing etc ? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #201633 30th Jul 2013 9:47pm
greasemonkey1
United Kingdom 2005 Range Rover Vogue Td6 Java Black
hoppy_70 wrote:
This one??
had same problem with mine and i do recommend that you either get a 6 tonne press or buy the whole unit with the bush already pushed in,as pushing the bushes into the round arm bit is a Censored nightmare...thought id save few quid by only buying the bush rather than the whole unit,,wish i hadnt,,was a nightmare to push out and an even bigger nightmare getting the bush back in,,ended up taking the bushes to a local garage who has a 10 tonne press,as apparently you need a minimum force of 6 tonne to get the bushes in without defacing them using the old sledge hammer method...
Post #212741 27th Sep 2013 5:43pm
