![]() | Home > General > What Tyre |
Pressure do you run the 255x50x20 tyres on , some fitters say 36 Front 42 Rear, others say 32 Front 36 Rear so kinda wondering what most of you Gents run on ...... |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
Should be listed on a sticker on the drivers door shut - mine certainly was when I had a puncture on Friday!
That's what i run on 42 rear's 36 Front, but a Kwik |
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 ![]() ![]() |
They have no idea |
Worth noting that they have to cover their backs so you may fing the pressures a little high in the rear unless you have 4 adults plus luggage!!!
I was told by the local dealer in 2003, and confirmed again when I bought the S/C last year to stick to the pressures on the plate. Apparently, it helps with the notorious "cupping" the FF RR is known for.
But the difference between unloaded & loaded on the sticker is huge. You need to use your judgement IMHO. |
Unloaded = 36 front and 42 rear on a 255/50/20 Loaded = 60psi all round. There are no smaller values for the 20" rims, only the 18 and 19" Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD! |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 413 ![]() ![]() ![]() |
I've always used the sticker pressure |
Completely even tyre wear if going by the sticker, and the car really does corner well |
