![]() | Home > Maintenance & Mods (L322) > Jump leads |
| Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267
I'd have said 25mm dia leads would do the trick but if you want belt & braces then Halfrauds do a 35mm set that they rate for diesels up to 4ltr. |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1883
http://www.halfords.com/webapp/wcs/stores/...yId_255204
| Simple1 Member Since: 01 Jun 2013 Location: Somerset Posts: 112
Need to be extremely careful with LR and jump leads. They can cause spikes that damage ecu's and other components when connecting them. You should really use an anti spike controller or a jump pack with built in anti spike to prevent damage. TDV8 Vogue SE 2009.
| A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973
I think thats 25 sq mm, not 25mm diameter... |
| J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651
Thank you everyone for your advice. The jump leads are for a forthcoming European trip and space will be at a premium so I will have no room for a jump pack. I've no idea what an anti spike controller is. Is it something you can attach to your jump leads?
| TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1201
Hi Chris -
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
i have just got a pair of heavy duty cables from ECP and have jumped to and from the car on several occasions without a problem.
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947
Feck have to go out and read the manual now out of curiosity |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135
I have several sets of these (in different vehicles) and rate them |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
I was just going to suggest Anderson connectors |
any ideas as to what sized anderson connectors would do the job? There is nothing that can't be fixed with a hammer😜😜
I use 175A and they've been fine - seems to be what most people use - I trawled a few Landrover & other sites.
Wired Anderson Connectors? I'll have to research that on Google. |
| RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932
Question
