Home > My Range Rover > Gearbox service TD6
Mustard
Gearbox service TD6
The box has been faultless since I have owned the rr so after much deliberation of 'if it aint broke dont fix it' I decided to go to my local 4x4 specialist and have the gearbox in my td6 serviced. At 95K I know its a real possibility for the box to fail so of course I want to try prevent this as much as I can. To my relief they knew all about the GM and ZF boxes etc so I felt reassured enough to have the work done. Drove the beast in first thing in the morning and they told me that it would be ready at the end of the day so they could leave the box draining for as long as possible, nice Smile
I Have only driven it home from the garage but it felt much smoother right away, I will go for a decent 'hilly' road drive tomorrow and see how it is compared to how it was and report back.
Post #201822 31st Jul 2013 11:54pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
What is it a td6? and where did you had it done? how much was it?
Post #201889 1st Aug 2013 1:45pm
Mustard
TD6 aka range rover, straight 6 cylinder, Turbo Diesel Engine
I had it done by a local 4x4 specialist in the NW
It cost me £200
I had it done in preparation to having it remapped which hasnt been done as of yet
Post #201894 1st Aug 2013 2:23pm
J90
France 2006 Range Rover Vogue Td6 Java Black
Hi Mustard,
Where in the NW did you have it done? Anywhere near Cheshire?
Ta, Chris
Post #201896 1st Aug 2013 2:54pm
Mustard
Hello Chris
Ill let you be the judge on how close it is to Cheshire LoL
Ian Barclay Motor Repairs
365 New Chester Rd, Birkenhead, Wirral CH42 1LB
Phone:0151 645 3342
Specialising in diagnostics for Land Rover, Range Rover, BMW and Mini.
MOT, Servicing, Air Conditioning, Bodywork, Welding and Repairs for all makes and models.
I do plan to use them again for some other works as they seem to know what they are doing and are well set out, IMO thats worth travelling for.
By the way im not affiliated with them in any way, I just pasted that info from google as they dont have a website that I could find. I drive past the place every day and its always busy with rangies so I thought thats good enough for me I'll give them a try. My gearbox seems very smooth but I dont know if thats just a placebo effect LoL, Ill beast it later on for a good test Thumbs Up
Post #201897 1st Aug 2013 3:08pm
Mustard
Tested / beasted and seems nice and smooth, Im not sure if its the same as before or better but at least its not worse Smile
Post #201964 1st Aug 2013 11:17pm
J90
Thanks for the update Mustard. Mine is on the 'to do' list and it's good to hear you can feel an improvement immediately after it's been done.
Chris
Post #202254 4th Aug 2013 10:25am
Mustard
Ok its been a good 2 weeks or so since the gearbox service and I have noticed 2 things that are different.
The first thing is when I start it in the morning, put it in drive and take my foot off the brake there is a noticeable delay in the rr actually moving forwards, its a good couple of seconds, now I know it never used to do that. Does this sound normal ?
The second thing is putting the rr in low range and also selecting HDC, im sure it was never noisy in the past but now when i select the low range it makes a horrible crunching / creaking kind of sound and as the rr moves around it just feels odd. I need to do some more in low range with HDC and pay attention to what it is doing.
Whistle
Post #204039 14th Aug 2013 11:57pm
mark1959
France 2004 Range Rover Vogue Td6 Giverny Green
Have a 2003 L322 TD6, have done 260000kms in it. Live in France. Local Range Rover garage says 'NEVER' to do this, but I was 'shuddering' when stationery, so took the plunge and had it done on a return trip to the UK.
Have now also done it myself twice all items available off the web, difference was immediate..... have now had it done three times...
Was advised by Phil at www.lrr.co.uk/ the first time it was done to drain and redo the oil after a couple of thousand kms as the gearbox holds 9 litres of oil and only 6 litres drains out etc.... Razz
Post #204535 17th Aug 2013 4:08pm
