Home > Wheels & Tyres > Tyres for a '71 Classic
chopdogs
Hi All
As some of you may know, I've just acquired a 71 2 door Classic.
I will need to refurb the original Rostyles and fit new tyres
Do any of you know if the new tyres will need to be tubed as per the originals?
Also, what's the tyre size that is most advisable for these wheels (mostly on road use)?
Thanks
chopdogs
Post #201924 1st Aug 2013 6:30pm
tolley
235 x 70 x 16
Post #201933 1st Aug 2013 7:20pm
Vogue
the original size was 205 80 16 for all Classics, a perfect alternative is as above the 235 70 16, that is the exact size I run on my Classic 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #201937 1st Aug 2013 8:01pm
chopdogs
Lovely, thanks!
Can I run tubeless tyres on the original (1971) Rostyles?
Post #201938 1st Aug 2013 8:06pm
Vogue
Not as far as I know. I am not aware of any tubeless rostyles off the original 2 door classic. There may though be later versions which were fitted to LR 90's in the 90's which are tubeless 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #201939 1st Aug 2013 8:14pm
TugRR
You've got to do it right !
205 x 16 Michelin M + S
You won't find any original ones, but virtually the exact same tyre was standard on the Defender 90 in the 90's. I'd start by looking for sets of Defender wheels with those tyres on ebay . . .
Thumbs Up Where do you go after one of these . . . ?
Post #201941 1st Aug 2013 8:15pm
Vogue
They were, I have both and the tyres were the same. XM&S 205's 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #201943 1st Aug 2013 8:18pm
TugRR
There was an alternative 205 x 16 by Firestone - rarely specced on road cars. They do, however, pop up at military disposal surplus places as they were the standard fit on the military TACR2 6 x 4 fire engines.
I'll take my anorak off now . . . . Whistle
PS If you're going for complete originality, a superb book was published years ago "Original Range Rover". When I'm back at home I'll send you the details. Very much worth looking out for ! Where do you go after one of these . . . ?
Post #201952 1st Aug 2013 8:58pm
You MUST do it right!
It has to be 205 x 16 Michelin M&S.
I would also personally be making sure they were the original tread pattern they used on the early ones, as it changed in the 1980s.
 Discovery 4 HSE
Post #201993 2nd Aug 2013 9:19am
And here is a fantastic site for information:
http://www.range-rover-classic.com/ Discovery 4 HSE
Post #201994 2nd Aug 2013 9:19am
Vogue
If you can find new 205 tyres in the correct tread pattern that are not aged then that's good to go Thumbs Up
If not I would rather put new 235's on rather than aged 205's that have safety issues. Personally I think the 205's look too small anyway and the 225 or 235 are a nice compliment to the vehicle and it looks just right.
Mine does and I have her sat on Goodyear 235 70 16 ATR's - they look well without looking carlos fandango / or as another forum member aptly described kebab shop! 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #202056 2nd Aug 2013 4:19pm
chopdogs
Thanks to all for the replies
I've bought some General Grabber AT 235/70s which I hope will be OK with the Rostyles.
There are 4 x Michelin M+S - with the correct tread pattern - with the car.
However, due to the obvious age of them, I will not be using them on the road
Once they're off, I may sell them - for show use only
chopdogs
Post #203200 10th Aug 2013 8:31am
Vogue
Good decision there, it's a usable safe option and probably the tyre which would have been offered as an option or fitted as OE if the classic was still in production 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #203204 10th Aug 2013 9:04am
TugRR
Big Cry . . . . keep it original !
You MUST keep looking for some more appropriate 205's . . . it's the law Whistle
I just hope for the sake of your upper body strength that your car has power steering . . . it was heavy enough with the skinny tyres ! Don't forget to check your steering at full lock both sides - you may need to adjust the lock bolts and reduce your turning circle.
In spite of the above, I'm terribly jealous - more pics please !
Post #203275 10th Aug 2013 7:01pm
chopdogs
No power steering......
Just have to see how it feels when they're on. Cheap as chips anyhow (£112 + £48 courier) so will sell them on if they're not right and shouldn't lose anything on them
More pics in my gallery
Does anyone have a lower tailgate knocking around?
Post #203537 11th Aug 2013 11:30pm
