![]() | Home > Technical (L322) > Body ECU ? |
Fame Member Since: 01 Dec 2012 Location: Oliveira do Hospital Posts: 42 ![]() ![]() ![]() |
After being parked ( in Sunny spot at 38C) returned to FF, only to find key dead..Unable to open doors. Managed to open with key turning in door-lock.Engine started but so did alarm. Engine responded to turning on and restarting a couple of times but alarm turning itself on and off all the time.Drove it 50 yards, and the steering felt very heavy as if power steering non -functional. Alarm recycling on-off.Removed negative battery lead, waited 10 minutes, replaced and drove home.(After replacing neg lead, I turned steering wheel to max lock L&R) drove home , along winding roads, but although better, steering not normal, only after about 20 minutes driving, steering suddenly felt as if power box was again functional and normal light feel.The alarm had stopped after the neg lead off, but started again recycling after I'd turned engine off , and then on again.But now, parked at home with neg lead again off, the bl---y alarm kept recycling and turned off after about ten minutes.
Battery is Varta, about 2 years old.After standing for a day the charge reads 12.6 Volts using a Fluke meter.( I have had readings of 12.4 or even 12.3 using cheap meters before, when using the Fluke, readings consistent at 12.6 or 7 . )When engine is running, I get 14.4 Volt. After a run, on parking, I immediately place the CTek 10amp charger. I think battery is okay? As is alternator?I have not had it on charge now for 2 days, and neg. terminal is off, I'll see what it reads now.As I 'm on batteries now, I often read on the Forums, that a battery only lasts about 3 years. My Defender, has a similar Varta 110 amp and it is the original battery supplied in 2001 , with the vehicle. Only last year,I started using a CTek on it. I drive often on very bumpy roads and vibration should damage plates, theoretically.But , Living in the country, I rarely make short stop, start journeys.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35821 ![]() ![]() |
not sure whats wrong but your alternator sounds ok if its pushing out 14.4 volts.. ... - .- -.
MoT necessary, so after standing for 3 days with neg terminal disconnected, and without the usual CTek connected, on reconnecting, charge was at 12.8 volt.Started okay and after 20 minute drive arrived at testing station.Turned engine off, set alarm restarted for test and passed with no problems.
With regard to 3faults all popping up almost together, Indie today put FF onto computer.Result? 3 faults listed for body ECU. Cleared. I'm not optimistic, hope it does not keep on returning with a final failure needing new body ECU. Range Rover Vogue TD6 2002
