Home > Maintenance & Mods (L322) > Help 2010 RR won't start |
This is the number for LR Assitance 0800 521 786 if its of any help |
2nd Aug 2013 10:23pm |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
Battery probably. Anyone there with a set of jump leads?
2nd Aug 2013 11:18pm |
Jer Member Since: 10 Dec 2010 Location: South Lanarkshire Posts: 15 |
Thanks, just back from camping. I phoned assist and they came out and got me started. Battery tested and was fine but I really did not think I drained that much power blowing up airbeds. Turns out their is a recall for 2010 TDV8's which included a wireing modification and new gel battery which I will book it in for. |
4th Aug 2013 2:44pm |
Did you leave doors etc open, have radio on, run a cool box, breathe on it funny, look accusingly in its direction, if so the battery will be flat.
4th Aug 2013 2:56pm |
Trust me you don't need to use it much to drain the battery to the point it will not start! You are correct about the recall for a new battery and wiring modification (or battery monitor to give it its correct name) After which, when the engines not running, you will enjoy a massive 10 minutes or so with the radio/ICE system on before you get a low power warning and everything switches off Great for the DVD system
4th Aug 2013 3:14pm |
