Home > Maintenance & Mods (L322) > Removing lower tailgate check straps.
kungfupanda
United Kingdom 2014 Range Rover Vogue SE TDV6 Mariana Black
I've got all the parts to add the small gas strut to dampen the lower tailgate opening but I'm having problems removing the old ones. They're well rusted and are held on with torx screws. I've tired with a cheap ratcheting screwdriver thing with no joy. I think I'm going to invest in better tools. Planning on getting a small 3/8" ratchet and the specific sized torx driver. Does anyone know the specific sized torx bit I need Tsomething?
Thanks in advance for your help.
Post #202503 5th Aug 2013 7:31pm
if you want a decent socket set you cant go far wrong with having a look at what halfords have got, there are a couple which would have all the tools you woul need in them.
i would normally be able to tell you the size but unfortunately i swapped mine last year and the replacements came with bolts not torx screws
i would guess that they would be about t30-t40 probably t35. There is nothing that can't be fixed with a hammer😜😜
Post #202504 5th Aug 2013 7:44pm
The existing bolts require a T40 torx bit.
As above, if you are going to buy tools go for a Halfords Professional Socket Set for about £70.
You get a lot more for your money than buying an individual ratchet and bit. Thumbs Up
Post #202511 5th Aug 2013 8:17pm
kungfupanda
Yep I've got the Halfords Professional socket set. It was around £100 as it was discounted. I assume I'll just need the driver bit then and possibly some penetrating oil.
Cheers for the help and info guys.
Post #202513 5th Aug 2013 8:34pm
Driver bit and penetrating oil. Thumbs Up
When you get the bit tap it into the bolt head with a hammer to ensure it goes all the way to the bottom of the recess to get maximum grip.
Post #202517 5th Aug 2013 8:37pm
If you are fitting the strut to the bottom tailgate dont be tempted to overtighten the self tapping nuts as they will strip the thread they have cut for themselves quite easily. There is nothing that can't be fixed with a hammer😜😜
Post #202518 5th Aug 2013 8:45pm
KFP pop round mine tomorrow and we will get them off Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #202526 5th Aug 2013 9:25pm
kungfupanda
Are you serious? Where are you based and what do you drink? Thumbs Up
Post #202565 5th Aug 2013 11:40pm
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
Mine were very rusted and wouldn't budge without a good set of mole grips. Essential tool!
Post #202566 6th Aug 2013 12:01am
Pm en route Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #202568 6th Aug 2013 12:07am
