Home > Maintenance & Mods (L322) > non oem sidesteps/front mud flaps
does anyone have non oem sidesteps/front flaps and if so ,did they fit ok and whats the quality of the materials... ... - .- -.
Post #202610 6th Aug 2013 11:32am
In a word S Censored E …..
Post #202666 6th Aug 2013 5:48pm
you have such a way with words.. Laughing ... - .- -.
Post #202670 6th Aug 2013 5:57pm
Well there are a couple of posts on here where members that have bought non oem ones have had nothing but grief with ill fitting screw holes being out of alignment Thumbs Up
Post #202673 6th Aug 2013 6:04pm
i figured that may be a problem but surely some non-oem fit properly.. ... - .- -.
Post #202679 6th Aug 2013 7:14pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Mine fitted OK although I've now removed them for off clearance when roading/green laning.
The spacing of the steps away from the sill had to be altered with supplied washers in the kit to get a nice flush finish but other than that and the awkwardness of fitting the mudflaps to the metal bracket it went OK (same fitting as factory I believe).
I got mine from PowerfulUK.
Post #202690 6th Aug 2013 7:38pm
thanks Colin...dont suppose you have any pics? ... - .- -.
Post #202691 6th Aug 2013 7:41pm
The chrome side tubes I've fitted to both my last 2 cars were non OEM and fitted fine Stan. Discovery 4 HSE
Post #202704 6th Aug 2013 8:15pm
Googsy
Stan in my view everytime I have skimped on acessories with copies have ended up buying the originals so false economy. Buy original and be happy and better off Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #202708 6th Aug 2013 8:18pm
i'm thinking steps to make access easier [wifes idea] but it seems i wil have to drill holes in the lower panel for the mudflap to screw into and i'm not keen to do that.. ... - .- -.
Post #202709 6th Aug 2013 8:19pm
Googsy
I drilled mine and regret it as I now quite like the flap less look but leaving them on due to holes.
I have seen some of those panels complete with side step mudflaps on the bay so if you could get two same colour you could swap them and keep non drilled versions if you ever remove steps Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #202711 6th Aug 2013 8:20pm
I'm having mudflaps fitted (as usual) this week, as I can't bare the thought of all that road grit, salt, spray etc flying off the tyres and hitting paintwork, why would you want that to happen?!! Big Cry Discovery 4 HSE
Post #202719 6th Aug 2013 8:41pm
Googsy
I think it spoils the lines of the car. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #202720 6th Aug 2013 8:42pm
Weejock
Sorry no pics.
I also regret putting the steps on now as I have the same problem after removing, holes left in the lower trim panel (same fitments as factory items). I put on factory style mud flaps to hide them. Annoyingly I put the steps on so my elderly parents could get inside easier, although they steadfastly always decided not to use them and struggle straight in!
Just as a thought, you can always recalibrate Access Mode to be a bit lower? Something I've not got around to doing but I've recalibrated Off Road mode another 1.5 inches higher for off roading duties.
Post #202723 6th Aug 2013 8:51pm
the wife thinks side steps will help protect the doors from dings in car parks etc ... - .- -.
Post #202725 6th Aug 2013 8:56pm
