![]() | Home > Technical (L322) > Strange Noises from up front.... |
turbo noise? ... - .- -.
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1080 ![]() ![]() ![]() |
If it was the turbo, surely there would be a drop in power and the warning light would show?
Simple1 Member Since: 01 Jun 2013 Location: Somerset Posts: 112 ![]() ![]() ![]() |
Mine does it too. Wind over bottle is accurate subscription of the noise, and usually comes after lifting throttle after a squirt up a steep incline. I put it down to recycling valves dumping boost pressure. They are controlled by rubber diaphragms so similar to one way valve in your household hose pipe (if you have one) |
Cheers Simple1, sounds like I'm not the only one! |
