![]() | Home > In Car Electronics (L322) > TV in motion. |
Mph28mph Member Since: 16 Jun 2013 Location: Wigan Posts: 112 ![]() ![]() ![]() |
Hi am trying to sort the tv in motion out.
Autobiography Member Since: 10 May 2011 Location: UK Posts: 925 ![]() ![]() |
It's illegal and stupid. Don't do it. |
oldcro Member Since: 17 Mar 2012 Location: Shetland Posts: 359 ![]() ![]() ![]() |
+1 |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3927 ![]() ![]() ![]() |
I keep forgetting that I have TV facilities at all even when parked up |
It's not illegal to have a rear view camera wired up chaps or are I missing something, if in reverse will the screen still work? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
If going through tv av on the tv module then yes you will need to activate TV in Motion for it to work when not in park. Can't remember if you need to if you are wired into the reverse cam av on the tv module though. A switch makes sense, then you can watch out the back anytime!
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
Yes, 'cos you will need Navcoder or posh diagnostics to set it. .
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8064 ![]() ![]() ![]() |
I used to do this with a TV in motion lead - the one I got had a aux video in - I used to run a camera behind my trailer where I had a fairly large blind spot from the mirrors |
