Home > Technical (L322) > Smokin...?
Parkheat35
2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Smokin...?
My 2012 TDV8 blows out a fair bit of smoke if you put the foot down. A lot of my driving is town and when I get on a motorway and accelerate I get A LOT of smoke. Only 10,000 miles so far. Is that normal?
Post #203177 9th Aug 2013 9:26pm
Sounds like you need a bit of a motorway blast to clear out the DPF Got - 2017 SDV8 Autobiography in Loire Blue
Post #203223 10th Aug 2013 11:34am
Vogue
+1 give it the gun !
mine is totally clean but I drive quite spiritedly 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #203226 10th Aug 2013 11:58am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Italian tune up requ'd
Post #203235 10th Aug 2013 12:39pm
Bigmick
Known problem on some 4.4 tdv8 engines where oil passes from the turbo to the DPF. Get it back to the dealer for repair under warranty Mike
Gone:-
2004 V8 Autobiography
1998 2.5 DSE
1993 200Tdi Classic
Post #203238 10th Aug 2013 12:50pm
roverron
Belgium 2012 Range Rover Autobiography TDV8 Ipanema Sand
Hi,I had the same problem, not often though.
The car was in at the dealer last week, they needed 3 days but after 1,5 days they got it ready to collect! RR 2012MY TDV8 AB ipanema sand
RR 2004 TD6 sold now
Post #203638 12th Aug 2013 6:05pm
DanRR
These cars build up oil in the secondary turbo in town driven cars due to sitting idle for most of the time, then when u plant it it spins up and dumps it straight through into the exhaust, its what most of the dpf issues are caused by, filling with oil rather than soot, theres a fix for this involving fitting a more beefy oil drain pipe system which seems to have cured it, take it to a LR dealer its covered under warranty..
Post #204571 17th Aug 2013 8:17pm
shalz
Kenya 2011 Range Rover Vogue TDV8 Santorini Black
^+1 DanRR
I had the same problem and iirc there was a thread on it. Mines currently at the dealer getting it fixed under warranty. It's a known problem so they wwill know what to do.
It seems to mainly affect cars that are mostly used fir town and short trips rather than constant long motorway miles. MY11 Vogue 4.4 TDV8 - "African Queen"
Post #204597 18th Aug 2013 4:48am
BlackPerth
Australia 2017 Range Rover Vogue SE SDV8 Mariana Black
awesome - same issue, car always used around town; thanks guys!!! Smile
Post #257844 6th May 2014 7:16am
BlackPerth
all fixed and running perfectly: Thanks to Australs Land Rover Brisbane, 2 x Technical Bulletins - reconfigured power train control module with latest level of software; and carried out modified turbo drain pipe
cheers and thanks to all for helping me help the dealer resolve this.
Post #262021 29th May 2014 6:03am
