![]() | Home > General > Diesel or Petrol Reliability - Your views appreciate |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35806 ![]() ![]() |
i would have thought that with the correct maintenance and tlc both would be equally reliable.. ... - .- -.
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
Stan, good point however both cars had maintenance done as and when they needed it at main dealers in accordance with guidelines etc. I know it is probably an unusual one as all cars are built differently and someone with 2001 Disco 2 V8 could have had a nightmare and a TD6 could be a dream. However I want a new FFRR and seriously considering an SC, trying to convince myself |
Years and years ago diesels were more reliable. They didn't have the very unreliable ignition systems of petrol cars of those days - just a mechanical injection system.
i was in the same situation and decided on the s/c and i'm very happy i did. ... - .- -. Y. O. L. O. . |
Kurt, that is my issue, years of petrols with no real issues now last 8 years with diesels!! yes slightly less in fuel costs however, I now believe false economy, backed up by maintenance costs, still have my old 4.2 Audi S6 that costs me nothing bar servicing and fuel, want an SC so trying to convince myself |
Benfelrr Member Since: 27 May 2012 Location: Wiltshire Posts: 301 ![]() ![]() ![]() |
have had 4 range rovers. 3 petrol 1 diesel All about the same reliability. Engine wise to date, trouble with none of them, petrol or diesel. Touches many trees quickly! |
The problem is mainly with service intervals being massively extended. Diesels are often thought of as super robust low maint units and they aren't, they still need looking after, especially with the turbos and tight tolerances of modern ones. Servicing a car early is the best way to make it last longer and so many ignore this and let it stretch on to 20k or so before a basic service |
Stan, did you have a diesel before? I want an SC. just trying to justify it, hope you understand |
yes i did Rosco, it was a td6 and a fine vehicle but it was a tractor and although i did some mods to it like blanking the egr valve i did not get much more mpg around town as i do now with the s/c and my s/c is so quiet... ... - .- -.
They are quiet aren't they ,,,,,,,, until |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3249 ![]() ![]() ![]() |
Like Stan, my first FFRR was a TD6. Whilst it was fault-free, and a great reliable car, my petrol (BMW 4.4 V |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3807 ![]() ![]() |
They put Diesel engines in trucks tractors and PSV's for a reason, reliability and economy over many miles. That said I have both petrol and diesel RR's and as long as they are serviced and looked after there seems to be very little in reliability between the two. What does make a difference is people messing about with cheap tuning boxes, cheap maps and generally flucking an engine up for the next owner.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
Now at 140k with TD6 (says something in its self), patchy history up to 86K, then with me for remainder. Only issue with engine in all that time was the oil particulate filter clogging up, which only really came about because it is not listed as serviceable in Rave, so I didn't know it was there! This forum sorted that out!
i wondered where my t*ts had gone... off to the dealers to get new ones... |
