![]() | Home > Maintenance & Mods (L322) > Solved ? What could be leaking in these pictures? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35698 ![]() ![]() |
Funny you should say that Ryan , my old td6 had a heavy steering at low speed and the servotronic valve was replaced but it still felt like it could have been better but i got used to it...now on my new s/c the steering is worlds apart from the td6 , its very light at manoeuvring speeds ..its a shame your not nearer to me as you would be welcome to try mine. it could be just a coincidence and nothing to do with the oil leak but you never know....i would certainly take off the under tray as suggested to try and pin point the leak [if there is one that is] .. ... - .- -.
• Oil Leak - Engine - visible via discharge out of under tray holes. On closer inspection and stripping components, this was reportedly attributable to the front offside driveshaft seal which was replaced.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8030 ![]() ![]() ![]() |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 ![]() ![]() ![]() |
Might be an idea like I have just done & take a look around the filter housing at the top. Someone in my case had siliconned the bottom of the filter housing rather than replace the three "o" rings. I opted to replace the whole cooler assembly & it took about 8 hrs. My oil was running straight out the back of the V & gathering at the bottom of the gearbox. Mine is now sat back on the drive without the wife moaning about the mess!! |
