Home > Maintenance & Mods (L322) > Tow Bar - Electrics options advice, please
TugRR
Hello All -
In the coming weeks, I'll be fitting a tow bar to my '06 MY FF.
I know I need to get the control unit, but what wiring options do those in the know recommend ?
I don't have a caravan and won't be getting one, but would it be wise to fit the twin set up ?
I'll be using the car to tow a small car trailer -
Ta V Much In Advance -
Thumbs Up Where do you go after one of these . . . ?
Post #203592 12th Aug 2013 12:08pm
As you are not going to have a caravan you have no need for the white plug, and one looks neater than 2.
However if you are going to be towing the same trailer i would opt to get the 13 pin socket then get an adaptor for a couple of quid to convert it to standard 7 pin. That way you have the best of both worlds, you have the option of the supplementary wiring should you ever require it, and only have one socket visible on the car.
It possible to get an adaptor of ebay for a couple of quid which can be plugged in to the 13 pin to gve you 7n (the
Old style black socket). Or you could swap the connector on your trailer for a 13 pin plug, they give a better connection and are a twist lock design so mane a much more positive coupling.
Either way it makes sense to me to fit it now, when you are doing the job. There is nothing that can't be fixed with a hammer😜😜
Post #203625 12th Aug 2013 5:45pm
Just a point,
If you fit a 13pin socket it is a testable item at MOT time. All connections within the socket have to work correctly otherwise it's a fail.
If you fit a 12N socket and/or 12S socket(s) they are not testable items at mot time other than requiring to be secure.
Imo fit the minimum required for your needs.
They all corrode thro time anyway.
Post #203627 12th Aug 2013 5:54pm
