Home > Maintenance & Mods (L322) > 2011MY front pads
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
2011MY front pads
Tried to replace the front pads today. Held by two retaining pins and a pinch bolt.
The pins have (had) a pointed end which I have managed to flatten - whilst bending my pin drift but no movement from them.
How much force do you need to use? And do you need an afternoon of hammering to get them out usually?
They are different to the pre 10MY tdv8 brembos.
Thinking of taking the car down to the Indy to get them to do it....shouldn't be that long a job for them.
Cheers,
G
Post #203249 10th Aug 2013 3:46pm
Mikey
Never struggled with them, it has to be said...
Try a bigger punch and/or hammer Thumbs Up
Post #203251 10th Aug 2013 3:50pm
stenh02
Mikey,
Sounds a plan Thumbs Up
Just concerned I had managed to flatten the points without moving them - so I thought I had been hitting them hard enough if i was deforming them.
I just didn't fancy having a broken caliper and no car.
Cheers,
G
Post #203257 10th Aug 2013 4:32pm
stenh02
It must just be me that's cr Censored p.
Can't get them to budge. I know the pre 2010 ones are easy but these are in tight.
Some posts on other sites saying they needed to cut them to get them out! Shocked
Left them soaking in WD40. Will see what tomorrow brings...
Post #203261 10th Aug 2013 5:31pm
Good luck! Discovery 4 HSE
1993 90 Tdi
Post #203287 10th Aug 2013 7:57pm
stenh02
Indy took 1.5 hrs to do them. They had to use the acetylene torch to heat them and then hammer them out.
It was the second set they have done on a 4.4TDV8's and they had to do the same for them. So, if you got a 4.4TDV8 maybe think twice before trying it yourself.
If I was closer I would have dropped it off to Mikey to try his magic on them!
Anyway, new pads all round and hopefully should be good for another 30k Thumbs Up
G
Post #204232 15th Aug 2013 9:37pm
Copper grease on the pins works wonders Thumbs Up
Post #204234 15th Aug 2013 9:40pm
stenh02
Aye, the factory obviously forgot to do that.
Was still on original pads.
G
Post #204235 15th Aug 2013 9:44pm
Factory and copper grease... hmmmm never the twain me finks Thumbs Up
Post #204238 15th Aug 2013 9:51pm
aus10RRW
Scotland 2012 Range Rover Westminster TDV8 Santorini Black
Remember speaking to the guys at Greenbank 4x4 and they said that due to "Health and Safety" reasons, Landrover are not allowed to use copper slip or similar on the factory line!!! Shocked Shocked
Post #204274 16th Aug 2013 3:33am
stenh02
Sounds a good plan! But nowadays surely the tolerance in these things are so smalll that a bit of copper ease won't make the assembly fall
G
Post #204278 16th Aug 2013 6:43am
Mikey
I think its more down to cost Rolling Eyes
Post #204279 16th Aug 2013 6:45am
