![]() | Home > Maintenance & Mods (L322) > Is this just a bulb out |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
It's a bulb, you have to remove the top dash and slide out the speedo/rev counter to get to the back.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1847 ![]() ![]() |
Just a bulb. Easy to do, but the vents and side panels can be a bit tricky to getting out and putting back in. Bit of a knack to them |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1235 ![]() ![]() ![]() |
Yep has just happened to mine too. The bulbs are about £2 each. Tom
Mustard Member Since: 25 Jun 2013 Location: North of South Posts: 299 ![]() ![]() |
thanks for the info, where can you get the bulbs from and do I need any special tools to gain access as I dont want to start stripping and then find I aint got the right bits and bobs |
Anybody know where I can get these bulbs from ?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Main Agents... |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
YAW000010 i dont do dealers when i dont have to. , (too many knob's walking about in pink shirts telling me not to park there, or there.) i normally order online, i bought 5 (set) from lrdirect, all posted, £1.60 ea. with postage vat etc, £12 the set. you need torx allen keys to remove dashtop and side vents, and then the binnacle 'pod' -no need to unplug, just swing it round, some long nose pliers get 'em out, quarter turn, and then they drop down into dash 'black hole' area, so put a cloth down to catch your new ones. careful with the dashtop, it comes towards you first, then up, and theres a grill to pop up first, and a speaker wire unerneath. i think youtube has a 'powerfuluk dash removal' video. with that piano music..... |
Thank you for your insight into doing the job & acquiring the parts |
Just ordered a set of 5 for £7.90 delivered from this company.
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Hi just found this on the search function. I have the same problem as mustard, has anyone upgraded to led on these as I would like to give it a try.
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
So do I. Want to do led upgrade as well. Saw someone has done it on a BMW forum.
Thanks for the reply. Does look nice.
This company also offers a 2010 style dial if you want to update the dial design too.
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 ![]() ![]() ![]() |
