![]() | Home > Technical (L322) > booming noise when driving |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
I had the same, sounds as though the sub woofer is cutting in or the rear prop is playing up......... eventually fixed for 1000 miles when I changed the gearbox filter/ oil................then the gearbox:( |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1036 ![]() ![]() |
Matt,
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
HI Phil
Yes it sounds like a sub wooded loud bass part of a song just like a booming or drumming noise. |
happens in manual mode as well when in 5th |
i have been reading loads about the LUC on the TC causing the issue between 30-50 mph going to do some tests with it tomorrow and see what the results are and if they are similar to what other people are experiencing. |
ok so i went out today and did some testing on the road.
smartone Member Since: 25 Jul 2011 Location: uk Posts: 29 ![]() ![]() |
Hi Did you ever get to the bottom of his ???
