![]() | Home > Technical (L322) > Auto stuck in second gear... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
i think it might have got slightly over heated and caused an electrical glitch in the gearbox ecu..lets hope that its ok now.. ... - .- -.
kiter Member Since: 04 Jan 2013 Location: Inverness Posts: 182 ![]() ![]() |
Mine did this as well, only once and with the caravan on the back and was after coming down a hill where I had the foot of the gas and as I picked away again it did exactly this. Mine has 146k on the clock and I did the gearbox oils and filters not that long ago - all seemed fine with no 'bits' in the old oil. Be intereseted in any suggested other things I could check out. |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
+1 for stans theory... Previously..
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1262 ![]() ![]() ![]() |
It could possibly have gone into the transmission overheat mode in which it limits the gearbox to 2nd/3rd in order to push more coolant through the trans oil cooler to bring the gearbox oil temp down to within limits.
jerrytlr Member Since: 02 Apr 2013 Location: France Posts: 66 ![]() ![]() ![]() |
hi Paul, I did wonder if it was in some sort of overheat protetion mode, however the car wasn't working particularly hard at the time - no towing or long steep ascents. There were no warning bongs or messages on the dash either - would you expect this if it went into overheat protection mode? Would it have logged a message of some kind in the ECU which I could get read by diagnostics?
