![]() | Home > Technical (L322) > Suspension compressor off |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
Hi, it is necessary to clear the fault, then it will be all ok. If the first compressor from new, he is 10 years old..., time to refit! Best rgs, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
rmackinnon Member Since: 14 Mar 2012 Location: Mansfield, UK Posts: 85 ![]() ![]() ![]() |
ok thanks - the pump did work well prior to this issue and i could get to offroad position in less than 30 secs, so i am hoping its still in pretty good condition.
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 476 ![]() ![]() ![]() |
I had the same two weeks ago. The issue I had was that I did the strut myself then had to get someone to come and clear the fault before I put weight back on the suspension as you need the bag to be inflated before it can take the weight. Sounds just like mine so all should be fine.
Good news!
