![]() | Home > Maintenance & Mods (L322) > How to change those pesky $%^& rear calipers on a TDV8. |
GGX Member Since: 31 Jul 2013 Location: North Wales Posts: 61 ![]() ![]() ![]() |
Make sure the hand brake is off, and you might have to manually back them off to, I think it's like the BMW set up where three is a star/spline to be rotated through the lug/wheel bolt hole rotate the disc to see it.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
it is similar to what goldsax says there is an observation hole on the disc, you use a screwdriver to move a star shaped adjuster to back off the handbrake pads from the hub, then pull off and refit new ones.
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2262 ![]() ![]() ![]() |
If you have 22s wheels don’t even need to come off! Current stable:
