![]() | Home > Technical (L322) > Rear Brake Caliper Compatibility for 06 MY |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885
No, they were only fitted from 2006MY-2009MY. Not sure if the 2010>on ones are the same |
| TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1201
Sorry, Mikey - What you have said was what I meant to type . . . .
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
At the same age the 4.4/3.6/3.0/4.2 shared the same rears when i was looking for mine. Mine was about £50 off ebay but i think i dropped lucky |
| Advanced Factors Site Sponsor Member Since: 31 May 2013 Location: Southampton Posts: 198
2002 - 2005 ATE Calipers - same as BMW 5 series
Thanks, chaps - I'll assess the options
Yes, as Steve has also said, 06-09 are all the same. It gets confusing because the 02-05 TD6 has the original style caliper, then changed it for the 06 TD6, and continued using them until 09MY |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Just remember that the calipers are handed, so you need to check which side they are for carefully, as so e are listed as lhs or rhs, but it delends on whether you are facing the front or rear of the car......
^ Yep, NMJ, agreed - both will be done.
I've sourced a pair of excellent used rear calipers via ebay for refurbishment. As NMJ suggested above - I'll sort both at the same time.
| All times are GMT |
