![]() | Home > General > Hi all new member |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
Do you know/did you change the cam breather when changing the oil? Quite important |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
Phil H Member Since: 17 Oct 2010 Location: Monmouthshire Posts: 34 ![]() ![]() ![]() |
Just had my TD 6 serviced, don't know if they changed the breather. Is it easy to see? |
No phil it's not unfortunately! Important to have changed though! |
If you are mechanically minded then yes its easy job if not then no. Best ask them if they changed it in the service if not do it. The filter is not expensive or you can get a for life unit if you want to . If not changed the filter clogs up and you start to get puffs of black smoke when you put yopur foot down and if left can lead to turbo failure so get it changed sooner than later. |
Thanks for the info. Will contact garage today. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
Welcome Steve9bug, sounds like you will be able to give some great advice to the ever growing numbers of TD6 owners joining the forum.
