![]() | Home > Technical (L322) > Towbar fitting |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
I'm glad you said they broke, thats how it sounded to me !
Exactly!
I'll try 6am - 1pm....I dont function well at 1am unless beer is involved ! Is this where I put the car details and a bit about myself ?........ |
Well with an ff you'll see more of it with all the sleepiness nights you'll be getting |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
https://docs.google.com/file/d/0B58lCjoHzo...sp=sharing
Thanks for fitting but had a few quotes and am considering a fitter do it..
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3252 ![]() ![]() ![]() |
Nick, I have a second hand but 2005 "as new" armature (not been fitted as far as I can see) and removable tow bar and neck sitting in my garage.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
the links are dead in this wiki anyone able to rreupload? Current stable:
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 612 ![]() ![]() ![]() |
Yep the post is a little old.
Johnniehec Member Since: 03 Feb 2017 Location: A a Posts: 28 ![]() ![]() |
That’s the wrong video, that only removes the outer cover of the bumper, no good for fitting a tow bar. The only valid part is pulling the sides out. You don’t need to take the black trim off and the four screws under it, nor the screws along the underneath. Instead you need to lift the spare wheel cover, remove the locker covers either side of the boot, where all the electrics are, then the floor trims either side to get at the four bumper bolts at each side ,8 in total and remove their 16mm nuts. The whole bumper then comes off in one piece (the bit he removed and the bit he left) there’s a much better video on here somewhere, I’ll have a look for it. |
stuart_2006 Member Since: 18 Jul 2018 Location: Holsworthy, Devon Posts: 132 ![]() ![]() ![]() |
The video I followed for full bumper removal is [https://www.youtube.com/watch?v=aISGcPDdkwc]. Having a ratchet spanner for the bumper nuts is a big timesaver. |
You can certainly do it that way but I would argue that you are making an unwieldy item into a heavy unwieldy item.
