![]() | Home > In Car Electronics (L322) > 2006 RR HSE Camera Upgrade with a 2010 Camera |
dmb Member Since: 28 Aug 2013 Location: maryland Posts: 2 ![]() ![]() |
from where did you buy the new camera harness |
muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 95 ![]() ![]() ![]() |
Use the part # 2008 HSE B. Grey
Thank you |
http://www.ebay.com/itm/LAND-ROVER-LR01614...mp;vxp=mtr 2008 HSE B. Grey
fideleo707 Member Since: 20 Feb 2014 Location: Florida Posts: 2 ![]() ![]() ![]() |
Has anyone tried this themselves? Level of difficulty? My 2006 camera has completely failed, will show a picture every now and then. Would love to do this mod but before I spend the money I want to make sure I know what I'm doing. In reading the thread it seems pretty straight forward but a few questions:
I have done this twice on my last two FF's... The first time I simply took some measurements at the main agents as to where the camera was on a 2010 car and drilled a new hole to mount the new camera in the same position as the 2010 car... Simply got some thick black plastic tape and covered the one hole over... Negating any need to shave anything!
How do you run the wiring? Where does the other end plug into?
kadas Member Since: 24 Oct 2012 Location: California Posts: 19 ![]() ![]() ![]() |
You need the new wire plug (part# is on page 1) the instructions are all on the 1st page. just read my posts. It was a while ago so I am not sure what went where thinking back. but it is a plug and play with a little shaving down of the new camera housing and then you need to cut open the new wire plug. |
