Home > For Sale & Wanted > [Wanted] Good (must be good!) LT95 Gearbox
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
I have a long tale of woe which I'll happily share with you but I'm in need of a GOOD LT95 gearbox for my Defender. Preferably one from an RRC with the higher output drive ratios but all possibles considered.
Post #206105 28th Aug 2013 12:44pm
Dolphinboy
Have u tried landyzone.co.uk?
Post #206165 28th Aug 2013 4:27pm
Cappo
I had a look at the classifieds but I haven't put a Wanted on there yet - will do tho, thanks
Post #206169 28th Aug 2013 4:38pm
Try motorhog.co.uk Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #206203 28th Aug 2013 6:17pm
Martin
Site Admin
www.defender2.net Whistle
Post #206204 28th Aug 2013 6:31pm
BrianC
What about a lt77 ?
Post #206207 28th Aug 2013 6:38pm
There are differences in where things end up IIRC Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #206264 28th Aug 2013 9:51pm
Cappo
Quite a lot of differences I think, and as the Defender has already been hacked to fit the 95 and all the controls, it's going to be easiest to replace like-for-like. It's enough aggro just changing the box (and massively unrewarding when the new box you fit is ten times worse than the one you took out!) so I'm trying to minimise the pain!
I have partly pulled the original box apart this evening, tempted to replace a bearing or two and see if that helps, but beyond replacing the main input bearing, its a complete strip of all the gears, synchros, selectors, etc etc to get to the rest, and I'm feeling distinctly girly about tackling that!! Laughing
Post #206309 28th Aug 2013 10:54pm
IS getting it rebilt not economical or getting the parts and DIYing it at all? Surely it cant be that bad as long as you have a nice big work bench and its all clean? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #206310 28th Aug 2013 10:56pm
Cappo
From what I can find, Will, rebuild opportunities are few and far between, and also of questionable quality (eg a steam-cleaned box = a fully-overhauled unit!). In addition, if you fit genuine parts, they're REALLY expensive (eg £100+ for the input shaft bearing alone, although you can get aftermarket ones for £20-ish).
Then, in order to service the gearbox (by which I mean the 4-speed gear unit itself) you have to start at the back, completely dismantle the innards of the transfer box, along with the rear output (and possibly the centre diff, not sure about that bit yet) before you can get to the back of the mainshaft to remove that.....and that's before you need 7 hands and 56 fingers to get all the synchros etc apart and back in!
So you can see why I'm erring towards a decent replacement box! My main alternative at present is just to replace the input shaft bearing and see whether that helps. I would do the layshaft bearings too (known for failing) but whilst it's easy enough to replace them, you then have to set the preload, and to do that you need the mainshaft out - see above!!
Ultimately it's do-able, sure, but it feels like more than I want to get into right now. Replacement boxes seem to go for £50-£100, I guess because they don't often fail, so I just need to find one and to be sure it's working OK.
Other possibility, well there's one on eBay at the moment for £4.99 with knackered layshaft bearings, I could buy that and use it as a learning tool, probably get more for it as scrap if it all goes pear-shaped and I just weigh it in!
Post #206343 29th Aug 2013 8:36am
BrianC
It would be a lot better with a r380 and a lot more of them out there so easier to get a good one
Post #206344 29th Aug 2013 8:41am
Cappo
If I went that route Brian, off the top of my head I would need:
- correct adaptor ring for the V8
- replacement clutch?? (I put a new one in when I put this knackered box in)
- different propshafts?
- change the floor for gearstick/transfer selector location
Are they 5-speed? I have a Fairey OD on this unit which gives me low-revs cruising.
Post #206345 29th Aug 2013 8:52am
An R380 is by far the nicest 'box out there, but that'll mean transmission tunnel changes and bellhousing changes. Not sure if there's an adaptor to fit the R380 in place of the LT95, but it may be worth looking on Ashcroft's site. But then you could always end up with a pup of an R380 as well...
R380's are 5-speed and you won't need an O/D but the 1.2 input gear on your t-box from a Discovery is a worthwhile move. My 110's got that and cruises at 80+mph.
The alternative is to take yours out and get it refurbed by a reputable man who knows what he's doing. See if there's a good gearbox specialist near you and go from there. It avoids buying a dog and also saves you a lot of time. Si. <This is my name.
Post #206346 29th Aug 2013 8:52am
Try and give Ashcroft a ring and see if they have any instock. If not then maybe ask them if they would refurbish one of your box's and how much and if they would be interested in buying your other one as im guessing you swapped it out you kept the old box as well?
Some places will do that for a reduced rate on the rebuild, but i wouldn't mention it until you have a price for a refurb box or to get yours refurb'd so you can haggle the price down a little more as their website makes no mention of the LT95 box, just the other main contenders... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #206354 29th Aug 2013 9:04am
BrianC
Ashcroft can make you a r380 with a short bellhousing so the gearbox sits in a better place. Lots of the racers have this set up
Post #206359 29th Aug 2013 9:18am
