Home > Technical (L322) > TDV8 Engine Whine
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
TDV8 Engine Whine
My TDV8 seems to have developed a whine or whiring sound from the front right of the engine. Sad
It sounds a bit like transmission whine,but is present whether the car is moving or static and is loud enough to be heard in the cabin.
The noise is also engine speed related (gets louder/changes pitch as you rev the engine).
Power steering seems fine, noise does not change if you turn the wheel.
There does not seem to be any loss of power.
The noise does not change whether the air con is on or off (Air con is not very effective).
The noise does not seem to come from the viscous fan.
Seems to be too far forward for turbo
PAS fluid look to be full
Oil level is fine
Coolant levellooks fine
Does anyone have any suggestions as to what could be causing the noise?
I am thinking about taking the aux drive belt off to eliminate work out whether it is aux blt driven items or something else, is it OK to run the engine for a 30 seconds with no drive belt on? 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #123532 24th May 2012 10:31pm
Does the TDV8 have a viscous fan?
Post #123533 24th May 2012 10:32pm
yes, it does have a VF. Well mine does anyway. There is nothing that can't be fixed with a hammer😜😜
Post #123534 24th May 2012 10:35pm
Andy_J
I think it does. there is certainly a fan driven off the water pump, so I assume that is a viscous fan 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #123535 24th May 2012 10:35pm
Martin
Site Admin
Did you sort this Andy?
Post #206347 29th Aug 2013 8:53am
Andy_J
Not fixed yet
I took it into my local dealer and they said it was the alternator, so rather than pay £750 to have the alternator replaced I have just decided to live with it until I can find time to take the aux belt off myself 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #206865 30th Aug 2013 6:04pm
Be careful - there are other threads on this - the 2007 alternator seems to be a bit weak.
If it goes, then you're cooked - it will flatten the battery and you're stranded.
Post #206932 31st Aug 2013 12:00am
Andy_J
Got AA membership for when the alternator eventually goes bang.
Not convinced that it is the alternator as I have not had any charging problems and I don't think the noise is coming from the alternator area. That's why I am tying to find time to get the aux belt off and check myself.
Does anyone know if it is possible to remove the viscous fan and Aux belt on a TDV8 without draining the cooling system? 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #206971 31st Aug 2013 11:33am
ebajema
Could it be the belt spanner roll bearing ?? I always replace the spanner roll as those bearings seem to not last very long. The spanner roll is quite cheap to replace together with the belt but some mechanics try to save money there (while maybe still charging you).
Hope this helps. MY 2010 5.0 SC Galway green and sand interior!!
Post #206998 31st Aug 2013 2:58pm
Andy_J
I have had to replace my alternator, and whilst the front end is in bits I took the opportunity to check all the idlers and tensioner for the aux drive belt.
The large idler is grinding away when I spin it, slight grumble from the tensioner, but guess I now confirm the source of my engine whine is the large idler on the Aux drive belt 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #241456 9th Feb 2014 7:17pm
Benfelrr
United Kingdom 2007 Range Rover Vogue TDV8 Tonga Green
Not to go off topic but the thing that most concerns me about your thread and posts is the word sold next to Lotus Carlton... ! 2011 Range Rover Vogue 4.4 TDV8
2003 VW Golf V6 4motion
2001 Range Rover Vogue 4.6
1982 Range Rover in VOGUE
1990 Range Rover Vogue SE
2007 Audi A6 Avant Le Mans Quattro S-Line 3.0 TDI
2007 Skoda Ovtavia 2.0 TDI L&K
2007 GSX-R 750 K7
Post #241543 9th Feb 2014 10:39pm
Andy_J
goot a good offer to sell the LC and as I didn't have a garage to keep it in, I took it before it started to rust and before anything major went wrong with it. Maybe buy another one in a few years or an Esprit 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #241641 10th Feb 2014 2:04pm
Benfelrr
very nice, one of the world's greatest cars, would love to own one one day! 2011 Range Rover Vogue 4.4 TDV8
2007 GSX-R 750 K7
Post #241676 10th Feb 2014 4:25pm
