![]() | Home > Technical (L322) > TDv8 drive stutter |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1862 ![]() ![]() |
An engine misfre. Get the injector compensations checked on a diagnostic machine |
GGX Member Since: 31 Jul 2013 Location: North Wales Posts: 61 ![]() ![]() ![]() |
No dash warnings? |
Definitely sounds like a sticky Injector buy some QUALITY fuel system cleaner and put that in then run for 20-50 miles it should clean it up and it should then be running smoothly. |
It's got 83k, which cleaner is best not to damage anything- only happens when it's cold. |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
I always used redex injector cleaner. I would buy it from asda as it was always on sale, and double dose it every few months. There are quite a few cleaners for sale, I don't suppose any are much better or worse than the others.. Previously..
sticky brake caliper ?? MY 2010 5.0 SC Galway green and sand interior!!
Just changed the rear callipers, also got a shaking steering under heavy braking. |
Injector, EGR or torque converter issue just starting! |
Completely seperate issue, warped front discs |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Sounds brake related to me, i would strip and clean all the calipers and then see what its like. I had a drive which felt like it was snatching a bit, turned out to be a sticking rear caliper, but if you have a judder under heavy breaking then i would get the runout checked on the front discs, however warping one of those big vented jobbies would be quite tricky.
Lumpy stuttering was worse tonight, seams to happen after a short drive and its left for a while then started agin. over 2000rpm it's ok, and once warm it's ok.
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
If it stutters more frequently/worse after being run then left for a while (i.e. started whilst still warm) my money is on an injector problem
ok, with that info it does sound like an injector problem. DOes it feel like a misfire/like one cylinder is not running correctly?
