Home > Maintenance & Mods (L322) > Wheel Alignment
supershuttle
Wheel Alignment
After my car valeting session earlier this week I tried to clean some threads off the inside of the offside front tyre - yes you guessed it - you can't wash off the threads exposed by shoulder wear on the tyre. I have ordered a couple of Nexens, it's only an experiment, but my questions are do I have the wheels aligned before or after fitting and should I get a fancy Hunter DSP job done and if so where up here. Thumbs Up Geoff
Post #206841 30th Aug 2013 5:09pm
Mark.abersoch
United Kingdom 2010 Range Rover Vogue SE TDV8 Bonatti Grey
If they were my tyres I would be getting them aligned at the same time they are replaced. 2009 TDV8 Vogue SE - Bonatti Grey
Post #206844 30th Aug 2013 5:22pm
Dolphinboy
immediately after will do. i used Protyre for £50. have never had uneven tread since. Make sure whoever does it has the right machine for a 4x4 as i think it can differ from 2 wheel drive?
Post #206858 30th Aug 2013 5:49pm
