![]() | Home > Maintenance & Mods (L322) > Retro fit reversing camera |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2068 ![]() ![]() ![]() |
Anyone fitted 1 to a non touch screen version?
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Yep, bought a plug and play cable off ebay for the video in.. slots in between an existing lead.. I think I swapped a pin to plumb the wiring where I wanted it. Wired a relay up to the reverse lights to provide a negative to the plug when required to flip the screen to the camera.
make sure your interface lead has the input for the reverse camera or you will end up with it on the av channel,
Thanks for the replies.
No it needs to be NTSC not PAL to keep things simple.
Cheers Elpeede.
Just off Junc 15 so only down the road |
