Home > Maintenance & Mods (L322) > Is it a case of RTFM - Brakes
supershuttle
My car has a bit of a problem with more than normal brake dust on the rear wheels. Took it to my local Independent and as it needed discs and pads I said to check out and even if one caliper was binding at all replace them both - a proverbial blank cheque. I also said they should check out the function of the EPB while they were at it.
They did find a problem with the EPB pads but nothing else and said the calipers were retracting as they should - I still get what I think is excessive brake dust.
I also tried to use the routine on my IDTool that relates to the EPB (unjamming procedure) but although the brake appears to work fine it reported a fault and suggested there was no module there?
I'd appreciate some feedback if any of you have had similar issues Thumbs Up Geoff
Post #207096 1st Sep 2013 8:58am
Perhaps LTFA... Laughing
Post #207098 1st Sep 2013 9:01am
Mikey
What brake pads were used? Some pads are a softer compound, wearing away faster, resulting in more brake dust. Could be something as simple as that Thumbs Up
Post #207100 1st Sep 2013 9:06am
