Home > Maintenance & Mods (L322) > Suspension Question |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34972 |
could be an intermittent fault in the abs sensor. ... - .- -.
18th Jun 2013 8:37am |
When my front wheel struts and bearings were replaced, the height sensors went out of range and that caused it to act up. Also the damaged one of the ABS leads setting of the HDC inactive, ABS and DSC inactive.
18th Jun 2013 8:48am |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
No recent work. It had a new windshield last summer, but I'm not aware of any low down/underneath type work. I need to get the car in for a routine service and oil change.
19th Jun 2013 4:27am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16192 |
It will more than likely be your battery voltage at the point of start up... If the battery is under charged during a start up, it will first flag up a suspension issue as that's the first "weakest link point" Now, im not saying your battery is faulty! But, for example...one day if you park your car at an event and keep returning to it hourly for the day and unlocking the car and opening doors before locking and leaving then returning an hour later, and so on. I bet you will get the message when you start up at the end of the day. Due to the battery drain from the ECU's waking up, interior lights and central locking going... So usually, your symptoms can be put down to battery voltage at point of start up... Up to you to look at your batteries age now |
19th Jun 2013 8:41am |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4989 |
sometimes at the car wash (and only there) i got this - just restart the engine and it is gone ..... |
19th Jun 2013 11:59am |
Thanks all! I don't know the age if the battery and alternator, but I had them tested at the last service after hearing almost all FFRR problems could be traced there. The battery and charging system both passed as OK and no remediation was recommended.
20th Jun 2013 2:15am |
well i got exactly that problem !! Since they changed my brake discs and pads and front wheel bearings i got this errors coming up ! What is the f***** cure ??? All my spelling errorz are belong to me! 2023 FFRR L460 2020 Range Rover Velar |
2nd Sep 2013 8:40am |
new abs sensors... ... - .- -.
2nd Sep 2013 8:41am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6356 |
I was getting the Suspension Fault message at start-up and sometimes during driving mine, it needed to have the air compressor re-work kit done by the dealer, wasn't much money and it fixed it. Discovery 4 HSE
2nd Sep 2013 8:44am |
well it started to occur after the repair i mentioned before and now when i brake hard on the highway it comes up or fast cornering at high speed...... All my spelling errorz are belong to me!
2nd Sep 2013 8:50am |
Hi Angel, my problem was cured by replacing the ABS sensors on the front wheels (that is where the work was done). The guys here are not very "careful" in their work. I have on many occasions moved the brake caliper such that the hoses weren't under tension bent around the socket crimp edge
well i will get it checked at my local stealer laterz... All my spelling errorz are belong to me!
2nd Sep 2013 8:56am |
On mine it threw up a fault, the HDC and ABS were out of commission so it was easy. Maybe yours is just dislodged or the connector is not fully seated so it loses contact a bit every now and then.
2nd Sep 2013 8:59am |
thanks mate All my spelling errorz are belong to me!
2nd Sep 2013 9:07am |
