Home > Technical (L322) > Wheel wobble
Wills640
2010 Range Rover SE Td6 Java Black
Wheel wobble
Does anyone have a cure for a quite harsh wheel vibration at around 50mph on a 2010 Sport?
22" wheels (genuine) no dings or dents, tried new tyres and balanced numerous times. Feels better initially after balancing but then returns.
Also my front brakes bind when hot. This has been back to dealer numerous times. New master cylinder, brake switch adjusted, servo rod adjusted, brake fluid renewed new discs and pads. Still does it. Normally after stop start driving and 'lifting' the brake pedal seems to cure it. It's driving me mad!
Thanks
Post #207310 2nd Sep 2013 6:53am
ebajema
Mmmmmmm this is a funny one. The brake link may be something. I remember a friend of mine had issues with an ABS ECU that was going haywire and started "applying" the brakes. Maybe that is what is happening to yours.
I suggest to ask your dealer to do a firmware upgrade of the ABS ECU, check the ABS module itself and see if anything pops up in that route of investigation. MY 2010 5.0 SC Galway green and sand interior!!
Post #207312 2nd Sep 2013 7:03am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Sticky brake caliper, mine did exactly this, touch the wheels after a run, if its hot, caliper stuck.
Post #207316 2nd Sep 2013 7:22am
ebajema
If the calipers haven't been changed yet (I assumed they had) then that is indeed the first point to check. RRs have a tendency to have their calipers binding. Mine has both rear calipers changed (common issue on SCs it seems). MY 2010 5.0 SC Galway green and sand interior!!
Post #207328 2nd Sep 2013 8:02am
Wills640
Calipers have not been changed but are perfectly free. Both front brakes are getting equally hot. When the brakes bind you can release them by lifting the pedal. when the brakes are not binding there appears to be adequate free play in the pedal. I should add that I am a trained Mechanic and own a garage. We don't see too many of these but the conclusion we came too was that it must be the abs/stability control bringing the front brakes on. I really did think the dealer would of pinpointed the fault straight away but not so. The last set of pads lasted 3000 miles. This gives some indication of the extent of the problem. Thanks for the advice guys.
Post #207547 2nd Sep 2013 7:49pm
ebajema
Keep us posted on what you find and how it was resolved. Looks like the ABS or HDC acting up indeed. MY 2010 5.0 SC Galway green and sand interior!!
Post #207568 2nd Sep 2013 8:33pm
i think you might want to join the RRS forum..loads of info for yours there. ... - .- -.
Post #207580 2nd Sep 2013 8:54pm
Monty1
England 2005 Range Rover Supercharged 4.2 SC V8 Rimini Red
had this on my td6 it was the tack rod end, soted it but now im replacing suspension parts way too often.
time to get rid for a newe model im thinking
Post #208987 9th Sep 2013 3:17am
