Home > Technical (L322) > ZF Gearbox not engaging on take off - Help please.
admisi
2002 Range Rover HSE 4.4 V8 Giverny Green
Hi, wondering if anyone can help me especially RRPhil. Am stuck in Spain and have what may be the dreaded ZF gearbox clutch problem, although the symptoms are slightly different. L322 2002 has done 55k miles, low for the year, I've owned it from new, never had gearbox serviced as "Sealed for Life" , been absolutely fine, smooth gear changes, no problems whatsoever. The other day I switched into Sport/Manual, and it suddenly missed a gear and then clunked in. Since then if I take off from stationary very slowly in D, the gearbox engages fine and I can continue on my journey without any problems - gears change up and down faultlessly - until I come to a standstill. Then if I try to take off with some gusto, the car revs up without moving then clunks into gear with a big bang - if done excessively it will go into Failsafe, which resets after switching ignition off and back on. Took it to a Range Rover expert here, hard to find in middle of rural Spain, he put it on the computer, told me the error codes were master control 2 and 3 , I think, said it needed 2 solenoids and ordered them. Sure enough, he received the parts, fitted them and it made no difference. Said old gearbox oil looked ok. Now he's telling me it needs taking to Range Rover Dealership for reprogramming after inserting the 2 solenoids. Can anyone shed any light?
Post #204792 19th Aug 2013 5:20pm
verydisco
Where about are you in Spain, may be able to help you find a proper LR Indy. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #204804 19th Aug 2013 7:14pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
I wouldn't be shocked if the parts did have to be coded to the car. Pretty much any parts with any electronics in them are coded unique to the car. Worth a check with someone who knows the system. My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #204810 19th Aug 2013 8:07pm
admisi
I'm in Costa Blanca near Javea.
Post #204815 19th Aug 2013 8:36pm
RRPhil
I’m assuming you have a V8 and not a TD6?
I agree that it doesn’t display all of the symptoms (yet) but nevertheless it does sound possibly like the start of the ‘bearing-then-O-ring’ problem, though 55k miles is certainly the lowest mileage I’ve seen for this to happen. I’m thinking that when you’re on light throttle the pressure requirements on the A-clutch to react the torque will be low so it’s able to hold. When you apply some throttle the torque requirement goes up so the pressure demand goes with it but the O-ring leakage prevents the necessary pressure from being generated and the clutch slips, the speed sensors report back to the ECU and it engages failsafe to protect the clutch. If the engine revs go high enough the pump produces sufficient flow to overcome the leakage and you feel the clutch engage with a bang. Having said all that, I would expect the problem to be worse when the fluid is hot, but you didn’t say that was the case.
Clearly new solenoids will make no difference. The Bosch transmission ECU has built-in adaption capability that will adjust for the characteristics of the new solenoids (it adjusts the clutch engagement pressures to maintain the shift times over the lifetime of the transmission). There’s no re-programming that the dealer can do.
Phil
Post #204820 19th Aug 2013 9:14pm
admisi
Definitely gets worse when the engine has warmed up. When cold it's fine but of course in Spain in August the car reaches full operating temperature within a few minutes. Could it be a clogged radiator?
Post #204825 19th Aug 2013 9:21pm
RRPhil
I admire your optimism but, no, I’m afraid that’s a different issue. A clogged radiator would cause the transmission to stay in its lower gears and to not upshift. It wouldn’t cause clutches to slip and generate the TRANS. FAILSAFE PROG message. The clogged radiator issue sometimes activates the TRANSMISSION OVERHEAT message when it gets bad enough (sump fluid temperature >140 deg.C).
Phil
Post #204829 19th Aug 2013 9:36pm
admisi
Mechanic still insists that it is electrical related, he's worked for land rover on these cars for years. It's there any way of narrowing this down? He says the gearbox is perfect in every way except that when it comes to a standstill it just slips out of gear.
Post #207353 2nd Sep 2013 10:42am
Sound like it COULD BE the gear mechanism on the side of the gearbox under the car. Try spraying it with loads of WD40 and move the lever through the gears a few times.
DO THIS before you do anything with the gearbox!
Post #207360 2nd Sep 2013 11:21am
ebajema
I'd suggest to follow Gary's advice first and then Phils. Clearly the advice of the guy in Spain is not working, he sounds a bit like a diagnostics mechanic, just change parts the computer tells you to change and don't think any further.
These sort of problems are seldom down to simply following the diagnostics, they require a bit of thinking on what could be causing the issue and with gearboxes, Phil is very very good. MY 2010 5.0 SC Galway green and sand interior!!
Post #207362 2nd Sep 2013 11:27am
Sorry having read the post in full Embarassed it seems unlikely to be mechanism but still DO IT!
Post #207363 2nd Sep 2013 11:30am
RRPhil
Still sounds ‘hydraulic leakage’ related to me. Could you maybe get him to remove the valve block
(he doesn’t need to pull it apart, just remove it as an assembly) and just do a visual inspection to check that the upper valve block doesn’t have a crack in it here :
Phil
Post #207384 2nd Sep 2013 12:50pm
admisi
Think I shall get it on a transporter to the UK and get it seen to there. Can anyone suggest the best place to take it to in the UK for diagnosis and/or gearbox rebuild that is efficient and most of all cheap, I can get it delivered straight to them and don't need it for a while. I don't suppose RRPhil would be interested in it as a project?
Post #209266 10th Sep 2013 9:55am
RRPhil
Well I’m certainly cheap! Unfortunately I currently already have four transmissions ‘on the go’ and I don’t have the facilities to remove/replace the transmission from/into the vehicle (I’m just an amateur working in my garage at home). Sorry I can't help at this time.
Phil
Post #209594 11th Sep 2013 6:17pm
admisi
Understood Phil, if I get it trucked back to London where I live, can anyone recommend someone in London that knows what they are talking about and is familiar with the ZF 5HP24 and the Range Rover L322?
Post #209600 11th Sep 2013 6:47pm
