Home > Maintenance & Mods (L322) > Indicator flashing ---
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
---when it is not meant to be.
While out today the right hand indicator started flashing at random for a few seconds at a a time. If I turn on the left or right indicator or the hazards all work normally, the random flashing is only when the indicators are off. When it did it again further down the road I stopped and checked outside and the front, back and side indicators were flashing as well as the dash indicator light.
My thoughts are that it could be a problem with the indicator flasher unit, would anybody have any thoughts and would anybody know where the flasher unit is located.
Keith 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #207564 2nd Sep 2013 9:26pm
When you say random, do you mean flickering, or flashing at the same rate as though they were working normally? Got - 2017 SDV8 Autobiography in Loire Blue
Post #207566 2nd Sep 2013 9:30pm
drakes
At different rates, sometimes faster than normal and sometimes slower. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #207569 2nd Sep 2013 9:33pm
And it's only the RHS? Got - 2017 SDV8 Autobiography in Loire Blue
Post #207570 2nd Sep 2013 9:36pm
drakes
Yes just the right 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #207571 2nd Sep 2013 9:39pm
I tend to agree that it could be a dodgy relay, or somethings energising it, like a dodgy connection on the steering column or slip ring.
Can you "provoke" it by putting the steering wheel in a certain position? Got - 2017 SDV8 Autobiography in Loire Blue
Post #207575 2nd Sep 2013 9:44pm
Post #207578 2nd Sep 2013 9:52pm
drakes
I did not try provoking it but it was just during "normal" driving not at full lock or any particular angle. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #207579 2nd Sep 2013 9:54pm
I actually think what Alan said is the most likely.... If you need anymore wiring info I have it all Thumbs Up Previously..
Post #207581 2nd Sep 2013 9:54pm
drakes
Post #207583 2nd Sep 2013 10:01pm
Sounds like one of those problems that'll be hard to trace. Not sure how much a relay would cost, but you have to start somewhere I suppose.
If it happens very regularly, maybe you could find a friendly local to swap relays with and see if it the fault moves to the other car, or stays with yours? Got - 2017 SDV8 Autobiography in Loire Blue
Post #207584 2nd Sep 2013 10:05pm
drakes
Anyone know where the relay is located? 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #207585 2nd Sep 2013 10:07pm
When you are parked, try turning the steering wheel about gently to try and get it to flash. Also, try and Gently tap the indicator stalk and see if it flashes.... Previously..
Post #207586 2nd Sep 2013 10:07pm
Did you read any of the info I posted? Previously..
Post #207587 2nd Sep 2013 10:09pm
drakes
The info refers to the LCM but not the flasher unit 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #207609 2nd Sep 2013 10:54pm
