![]() | Home > Maintenance & Mods (L322) > Headlights beam high up 2012 facelift |
No they dont support self levelling its one of the wires that becomes a spare after conversion. I asked this question after doing my own conversion. Apparently you can adjust via a number of screws although I havent done it yet. Hope that helps |
DTaylor Member Since: 15 May 2013 Location: Manchester Posts: 163 ![]() ![]() ![]() |
So do you currently just live with it a little higher also? |
No I havent been driving at night since doing but its been on my mind as a possible to do. Present :2008 TDV8 HSE
If you do it let me know how please pal |
I was going to bring it to a kwik fit or similar as they could line it up correctly. Present :2008 TDV8 HSE
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Guys, its very easy to do... Open the bonnet and look at the headlamps, there is two allen key head adjusters. One for height (the outer one closest to the wing) and the other one is for L & R adjustment |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6823 ![]() ![]() ![]() |
MOT failure if they're out of the permitted range.
My test aint due until Feb and I havent been driving it at night. Even if I can adjust I dont know what parameters are that I need to achieve. So I will ask someone in the know to do it |
brilliant just done now, getting bored of people pulling over constantly
How do you know when they are lined up properly? Present :2008 TDV8 HSE
I dont. Just made them alot lower for now so there not flashing people. I tried lining them up against the reflection on my garage |
