![]() | Home > Technical (L322) > Where is the relay for the heated steering wheel? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
the relay is on the back of the glovebox fuse board... .. ... - .- -.
| Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201
Cheers do you know how to get the fuse box out? And when it's out which relay is the one for the steering element? 2003 Vogue 4.4 V8 Java Black |
i dont , sorry...it might be in RAVE or someone might know.. ... - .- -.
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
I'm guessing the fuse you took out was Fuse 29 … |
Yeah checked fuse 29 - sorry if this is a dumb question but is the relay likely to be attached to the rear of that fuse? The RAVE download won't work for me! 2003 Vogue 4.4 V8 Java Black |
Feed from the positive battery terminal (C0192) is supplied to the steering wheel relay and fuse 53 of the passenger compartment fuse box (C0632) on an R wire. Fuse 53 (C0583) is connected to the ignition switch (C0099 on Td6 vehicles, C0028 on V8 vehicles) by an R wire. When the ignition switch is turned to the 'ignition' position, current flows across the switch (C0099 on Td6 vehicles, C0028 on V8 vehicles) to the steering wheel relay coil (C0585) on a G wire. The steering wheel relay coil (C0585) is earthed on an N wire.
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307
there is also a module under the air bag, i would check here to see if you are getting the 12v up to the steering wheel, does your light come on the button V8 facelift Range Rover Autobiography 22" wheels.
Control box at bottom of steering wheel behind airbag...
Light does come on but just for a second, can't get it to stay on. 2003 Vogue 4.4 V8 Java Black |
Ahh, steering wheel is probably buggared then... Changed mind last week with the same symptoms... Luckily still under manufacturers warranty... Can you borrow a wheel to check both box and wheel...
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
Mine is doing the same, on for 2 seconds then switches off... I just took it that the element was gone in the steering wheel. I take it that this is quite a common fault? Might treat myself to a new one, but to be honest, I really can live without it. Previously..
| mark1959 Member Since: 28 Aug 2010 Location: North West Posts: 9
Hi posted this under "Heated steering wheel problems" but no replies received, so reposting here in the hope somebody has a pointer!!
Mark, sorry mate - this problem for me was fixed by replacing the entire steering wheel . Sorry I realise that doesn't help but didn't want to leave you hoping I had the solution! 2003 Vogue 4.4 V8 Java Black |
I managed to track down a second hand ECU, the one that sits in the steering wheel about matchbox size, swapped the units over everything now works fine
| All times are GMT |
