Home > Maintenance & Mods (L322) > Who in London can lower my suspension?
Page 2 of 4 <1234>
Tallsaj
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
iid tool buy or not to buy?
Hi I need a good place to my iidtool from with good after service I rang island 4x4there price was the cheapest but they were not helpful they just said go the site get info from there. I have a sc what else can u do on iidtool can u update software on the range?
Post #207688 3rd Sep 2013 12:19pm
have a look here,
http://www.gap-diagnostic.com/products/iidtool.html
or search the forum , there's an informative Q&A thread.. ... - .- -.
Post #207689 3rd Sep 2013 12:23pm
Tallsaj
Yes I have seen this but big diff in price from the normal to the Bluetooth one
I really want it to lower my car and prob update some glitches
Post #207699 3rd Sep 2013 1:41pm
ebajema
There are a few forum members with multi VIN licenses that are willing to help other members with all kinds of stuff, like Ajay for example.
That is a cheap option. If you go for IID, I'd suggest to go the full monty. Reason I say that, I use full functionality of the Faultmate because I can and I would be totally p Censored d off if I couldn't do something with the unit i had that a more expensive one could. But bear in mind, I have always done a lot of work (especially fault finding) in my cars due to bad experiences with dealers etc. (mostly from others as I was raised by a very good mechanic/fault finder Very Happy ).
Now if you are not the type of person with an OCD on getting things right and wanting to have control, then full functionality is not a big issue. If you do like or expect to want to do more stuff in the future, it helps.
It also helps to show a good indy that doesn't have the right diagnostics equipment to sort out your car or to check if you are not being bullshitted by a dealer/indy/mechanic by knowing what is going on. It also helps with faultfinding at no cost because you can provide info that a dealer/indy would charge for !!!
If you really just want to lower your suspension then keep looking on the forum for someone that wants to help out and visit them, treat them to a nice lunch or something and you are sorted. If you expect to be wanting to do more in the future and/or don't want to be lose too much money on dealers/indies, then I suggest you invest in a full function IID or Faultmate. MY 2010 5.0 SC Galway green and sand interior!!
Post #207704 3rd Sep 2013 2:22pm
Tallsaj
Lowering
Ok next question can any one help me to lower my sc if u have multi licences then I can decide to buy a iid full monty myself)
Post #207707 3rd Sep 2013 3:24pm
Tallsaj
ebajema can u for example what else can u do that is really useful in the iid?
Post #207708 3rd Sep 2013 3:27pm
ebajema
I don't have the IID myself but there are some good descriptions on the forum on what they can do. I have a Faultmate and they can do the same plus update the ECUs of the car (an option that I believe is not yet possible with the IID but may be coming in the future). Because I am in a "remote" location, the full functionality (similar to the official LR Testbook T4) plus access to the original LR firmware is vital.
I have updated my transmission and engine management ECUs for example.
I can change every setting that the FFRR ECUs have, read and clear all the fault codes, do live recording of values generated by the sensors etc. etc. etc. MY 2010 5.0 SC Galway green and sand interior!!
Post #207711 3rd Sep 2013 3:37pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Why not just stick a knife through all the air-bags and ride it on the bump stops?? Very Happy
I really cannot understand people who want to 'lower' or put 33" wheels on a car such as the Range Rover! If you want to go and do stuff like that buy an X5 or some other 'wannabee' Range Rover!!
Post #207712 3rd Sep 2013 3:37pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
The >60 mph does not work on the SC. There is a "high speed mode" which activates over 100 but a few seconds below 80 and it raises again.
I have the IID tool and it's absolutely brilliant for the price. One quick example. I had an issue with the Air suspension compressor and using the live values stuff it was really easy to diagnose.
Similarly reading and clearing faults from all ECUs.
Reprogramming the CCF for silly things that you might like on a "whim" such as lazy locking, follow home lights, auto locking etc. You can do all of them.
Mine has paid for itself even just in diagnostic time. The support from the guys in second to none.
One caution though if you go too low the ride is HORRIBLE. It's designed with a given pressure in the springs as a compromise between compliance and ride height. If you lower the ride height (reduce the pressure) then you feel all the bumps a lot more as the bag if softer.
That's another great thing about the IID tool- You can set it up, try and and revert if necessary!
Post #207719 3rd Sep 2013 3:49pm
Tallsaj
Wow that is a really good option to reprogram the cars ECU and gearbox my gearbox takes too much time to change and in higher revs. Why stab the bags the vogue is a beautiful machine they should have made it lower from the factory. Forget the X5 and shabby sport Full Fat all the way;)
Post #207727 3rd Sep 2013 5:08pm
Tallsaj
Been asking iid tool dealers apparently only diff between the normal and bluetooth version is the blue tooth been quoted cheapest 270 gbp inc del for the normal one and the bluetooth version 440 gbp inc del Unless some 1 else can supply it cheaper? . A big diff for looking FLASH Cool Boy the sc looks Sexy Dropped Very Happy
Post #207736 3rd Sep 2013 5:53pm
Tallsaj
Also eric at Salop 4x4 been helpfull and Paul at IR Parts Top peeps Cool
Post #207737 3rd Sep 2013 5:56pm
Tallsaj
Autologic
Any one in the Midlands got access to an Autologic need to update my gear box and car ECU.
i Run a Small cake shop so Got some nice Fesh Cream cakes Very Happy
Thanks in Advance
Post #207739 3rd Sep 2013 6:00pm
ebajema
I'm going to stay away from you, trying to lose the vacation kilos first Wink MY 2010 5.0 SC Galway green and sand interior!!
Post #207752 3rd Sep 2013 6:38pm
Tallsaj
iidtool or autologic
ebajema I have been reading up on the fault mate its a nice piece of kit it has a lot of functions and is well established. Apparently u can program the cars gearbox and engine ecu thats auto logic stuff but a lot cheaper. From what I can see is iidtool is heavily advertised and has only been out less than a few months. I think I prob go for the auto logic well underrated
Post #207912 4th Sep 2013 11:47am
Page 2 of 4 <1234>
