![]() | Home > Technical (L322) > Big improvement after EGR valve removed |
| Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951
I've fitted the blanking kit finally, having had it for months in its box. There is a noticeable difference now and I can only assume by looking at the valve I took off, that it was u/s.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35875
did mine and have always been a fan of the blanking kit... |
| andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 982
how long did it take to do, i have seen the thread on the wikky but whats the real life experience? |
Start to finish with no interruptions, I reckon it'll take anyone with average ability half and hour tops.
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
May I ask which kit you bought Noddy? |
@Andy, this mod is one of the few that actually does make a difference..it allows cool air in which makes the engine run better... ... - .- -.
..but it did cost a bit more Eugene.. |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837
Can this definitely not be done on the TDV8?
I bought it off eBay. The company name escapes me at the moment. I'll do a bit of digging later and find out |
i've not heard of it being done on the tdv8 Alan... ... - .- -.
| plumajp Member Since: 18 Jul 2013 Location: bridgend south wales Posts: 73
why dont people just pull the vacum hose off the EGR body and bung/ plug it, then the EGR does not operate and cool air flows into the inlet manifold. thats what i did to mine and it took 15 seconds, no removal of covers, just a cheapo interior screw i had lying around my nut and bolt tin. |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
Pulling the vacuum hose off and plugging it is fine but how do you know the egr valve is closed to the gas recirculation port?
if its jammed open, then surely a fault would show on OBC.
The egr valve on a TD6 is a mechanical device only with no electrical input/output which is why it can be removed in the first place, its performance can't be monitored with a diagnostic tool.
