| no problems with the battery - starts up fine.
I have a volt meter connected to the cigarette lighter in between the seats.
 when i first climb in, it shows between 12 and 12.6 depending on when last used and for how long a trip.
 when cranking, voltage drops and i have seen as low as 7.5.
 if battery was low, volts then climb to 14.6 or 14.7.
 all quite normal.
 now yesterday I noticed whilst cruising up the M23 (had done about 100 miles up till then), i noticed that when under power volts were showing 13 or 13.1.
 when i took foot off gas, volts went to 13.8.
 foot back on power then volts back to 13 or 13.1.
 any idea for the voltage fluctuation?
