Home > Maintenance & Mods (L322) > Bosch s5 silver 110ah 020
Page 2 of 4 <1234>
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Thanks Gents - new battery ordered. "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #207656 3rd Sep 2013 9:16am
Polux
2005 Range Rover Autobiography 4.4 V8 Monte Carlo Blue
its the only battery that should really come with a RR
Post #209325 10th Sep 2013 1:14pm
^ agreed .. Thumbs Up ... - .- -.
Post #209330 10th Sep 2013 1:28pm
Tuts
MrP wrote:
Just checking but is this battery ok for the 4.4v8 petrol as well? (Yes it's new battery time again)
Yup, it's the one I've got on my 2003 v8. 2003 Vogue 4.4 V8 Java Black
Post #209364 10th Sep 2013 5:14pm
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Purchased the Varta .
£96.50 delivered !!
That's the cheapest I have seen for that or the Bosch for a while .
Off the bay, 99.9% feedback seller
http://bit.ly/1eWUbcM
Thumbs Up Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #227480 7th Dec 2013 9:34am
E4 GUY
Apparently had I downloaded their App from the App Store
"Battery Megastore" you get a further 10% !! Big Cry Alcohol and eBay is never a good mix
Post #227484 7th Dec 2013 9:53am
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
fitted a varta 020 a month ago as my 8 year old battery had had it 020 is the one for the td6.
Post #227547 7th Dec 2013 5:22pm
daveo
looks like its a new battery or me as well, can i sqeeze in the 020 in my 4.4 petrol. is bosch and varta made by the same people, i was offered one of those AGM batterys but i fault you have to have a differant alternator to charge them... V8 facelift Range Rover Autobiography 22" wheels.
Post #227676 8th Dec 2013 7:23pm
Varta and Bosch batteries are both made in the same American owned Johnson Controls factory in Valencia. Bosch brand owned by Bosch of course, Varta & Optima brand owned by JC Inc.
Post #227678 8th Dec 2013 8:08pm
You could use an amg without issues iirc as they normally just upstate the alternator to boost charge them quicker as they are often used in stop start cars due to the amount of quick drains they get from starting the cars up and the need to get he battery charged quickly but in a 4.4 ff you'll be fine. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #227727 8th Dec 2013 10:57pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
My new battery made a huge difference. Best £112 spent on the Fatty so far!
Post #227730 8th Dec 2013 10:59pm
daveo
so what battery did you fit paul. V8 facelift Range Rover Autobiography 22" wheels.
Post #227732 8th Dec 2013 11:05pm
paul271
Daveo i fitted the Bosch S5.
Bit of a faff to get in but well worth the swearing and nipped fingers!!!
Post #227746 9th Dec 2013 4:27am
johnboyairey
i bought the s5 02 bosch, and have the receipt tucked away nicely. when I bought my FF it came with a 1 yr old s5 in it, but it was flat.(car was a non runner you see,) I believe it had been overcharged, or left completely flat.... as it had a very short charge life. it had been bought from Halfords. I took it in for a garuantee check, but they are adamant that it charged and holds charge. I suspected they didn't want to have back on warranty, so I bought same battery from europarts with discount for about £120 I kept their garuantee, and battery has been excellent on the 2002 4.4 I drive. never let me down, no starting issues, no weird electrical issues either. been on for about a year nearly. there is quite a lot of crap on the net about batteries, and there are problems for newer FF owners and programming batteries for these models at dealerships. With a digital multimeter it is possible to determine correct battery charge and normal battery voltage. (Halfords seem to think a little simpler) mine has the blow-off charged connector on the posi. procedure. turn off car and open bonnet, (leave drivers window down incase a central locking problem) open bonnet to service position... allow 20 mins for airbag/nav shutdown, remove neg and then posi, put a rubber glove over each terminal in case they try to flick back to terminals. de-clamp etc. carefully remove black trim poppers and watch them ping out and down drain! prop up plastic with some cardboard, stand on toolbox and lift battery up and onto bulkhead, and reverse procedure. try to get neg terminal onto post quickly, to avoid arc'ing. have key ready incase of alarm. set clock and nav date etc. note...make sure you haven't uncoupled the yellow cable for the terminal blowoff circuit. its thin, and short and gets wrested with pulling the battery cables around. check before you reteminate. then check airbag light etc.
Post #227773 9th Dec 2013 11:28am
daveo
i will go for the bosch 020 battery, any europarts codes floating around.. V8 facelift Range Rover Autobiography 22" wheels.
Post #227839 9th Dec 2013 9:06pm
Page 2 of 4 <1234>
