Home > Technical (L322) > 'Check Dipped Headlight Bulb'
Mapmuppet
Guys, any ideas ?
Only one headlight is working and getting the above message, have swapped the bulbs, just need to make sure I've covered all my options before booking into the local dealership.
Cheers
Post #2083 3rd Jan 2009 9:23pm
First things first;
Does it now work? if one of the bulbs is gone, replace it and then see what it says (assuming you didn't swap it from one side to the other)
If it works and its just a message on the dash I'd be inclined to ignore it, after a few resets, it's likely to go away on its own. Check the fuses too.
Do you have xenons? Discovery 4 HSE
1993 90 Tdi
Post #2084 3rd Jan 2009 10:02pm
Mapmuppet
Thanks for the swift response, much appreciated.
I did swap the bulbs over and the 'non-working' bulb works on the other side, just very strange as speaking with the dealership they have stressed that Xenons don't usually fail and it is probably due to the main control unit.
Is it worth replacing the failed Xenon bulb before booking the vehicle in ?
Cheers
Post #2091 4th Jan 2009 6:51pm
If the bulb that was not working then works on the other side, then its not the bulb. I have no idea how much xenon bulbs cost but I doubt they are cheap. It could be an electrical gremlin or as the dealer says, the control box.
Is the car under warranty still? If so, I'd be stating to the dealer that it says in the owners manual that 'xenon bulbs last considerably longer than halogen bulbs' and therefore why should you be finding an issue now. Discovery 4 HSE
1993 90 Tdi
Post #2095 5th Jan 2009 10:47am
Mapmuppet
Problem Solved, having spent a couple of hours out in the cold it was a loose connection on the back of the casing. Have cleaned with WD40 and all is working now.
Thanks for your help with this Wink
Post #2132 7th Jan 2009 10:34am
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
WD40 were would we be without it Rolling with laughter
Post #2141 7th Jan 2009 1:43pm
