Home > Technical (L322) > "HELP"SHUT DOWN!!
stevb
2008 Range Rover SE TDV8 Java Black
"HELP"SHUT DOWN!!
Hi All,
Thought that if any one could help somebody on this forum will know. Just traded in my 08tdv8 for a 2yr old sc autobiography. Fantastic car but a slight niggle! .....if sitting in the car parked and ignition off, I put the radio on within 3 to 4 minutes a message appears "SHUTTING DOWN LOW POWER" and everything closes down if I press the radio on again the display then reads "LOW BATTERY START ENGINE" the engine starts no problem . The dealer has replaced the battery but dosent have a clue as to why this is happening. Here is the bit where I really need advice! The dealer says that this could be normal!!!!! TO SAVE THE BATTERY. I used to be able to sit in my last ffrr and even watch tv and have the prs heater on without any probs. Any advice would be great.
Post #209119 9th Sep 2013 8:55pm
i think there's a software update for the battery problem... ... - .- -.
Post #209120 9th Sep 2013 8:58pm
stevb
Thanks Stan, I will tll the dealers tomorrow when they phone
Post #209125 9th Sep 2013 9:13pm
if you search ''battery problem'' there's a few threads relating to the 2010 onwards battery/software problem. ... - .- -.
Post #209127 9th Sep 2013 9:20pm
wealy
Mine has done exactly the same after a few minutes?
Did the dealer give you an answer?
Post #209355 10th Sep 2013 4:22pm
stevb
Dealer didn't telephone me today so still waiting to find out whats happening. ill let you know
Post #209389 10th Sep 2013 6:57pm
Dave ray
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Jump thread
Mine did it the other day but was saying monitor shut down to overheating sorry to jump your thread
Post #209415 10th Sep 2013 8:23pm
wrong thread Dave..this is a 2010 battery problem which is corrected by a dealer software update and a new replacement battery.. ... - .- -.
Post #209417 10th Sep 2013 8:25pm
Dave ray
Sorry
Post #209436 10th Sep 2013 9:11pm
Range Rover LSE
Mine is a 2010 and does the same, it follows on from when they updated the software and fitted a new gel battery, the software change also cut down the amount of time that the FBH will run for after switch on. As I recall the software mods were part of a service bulletin, but I'm sorry I cannot remember which one. Range Rover LWB HSE L460
Gone Range Rover Sport 2023 D350 AB, RR L405 Autobiography SDV8, RR L405 VSE SDV8, RR L405 3.0L VSE, RR L322 BM 4.4, RR Sport, RR L322 TDV8 Vogue, Disco 4, Disco 3 (2 off), Disco 2 and RR Classic & RR LSE
Post #209459 11th Sep 2013 12:03am
Range Rover LSE
Sorry I should have said but I think the software mod was put in to protect the battery and problems people had been having, the result is that it is very protective of anything that is power hungry such as the TV and soon goes to shut it down. Range Rover LWB HSE L460
Post #209460 11th Sep 2013 12:07am
so am i correct in assuming that if the 'shut down' error appears then you must have the software update already.. ... - .- -.
Post #209486 11th Sep 2013 9:33am
Range Rover LSE
I would assume the software mod is in place, it was all part of the service bulletin which changed the battery to a gel type. I bought my car a little over a year ago from a main dealer, I had no problems with the car, battery was fine etc, however I noted on TopIX that there was this service bulletin outstanding so I advised the dealer and they carried out the job, changing the battery as well as the mod at the same time. Following which the timing for the FBH was reduced and the warning described appears.
I do reasonably long runs most of the time so the battery is always well charged however the warning/ shutdown occurs after probably about 10 mins when using the TV, this never happened previously. but I also notice if i do a few short runs in winter for example the warning comes up quicker, it suggests it is very protective of the battery and I have never encountered a problem starting up. Range Rover LWB HSE L460
Post #209505 11th Sep 2013 11:10am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
the software mod is LESS protective of the battery than the factory setting.
so the warning should go away.....
Post #209885 12th Sep 2013 6:49pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
...see also
http://www.fullfatrr.com/forum/topic18326.html
No matter how I talk the landrover....I cant seem to get through to them that the AGM / BMS / software updates are effectively making accessories on the car defunct to a degree.
Post #210007 13th Sep 2013 10:43am
