![]() | Home > Technical (L322) > Losing water |
| tony1kenobee Member Since: 07 Jul 2012 Location: SOUTHAMPTON Posts: 145
Hi guys,I have a 2003 4.4 v8 autobiography FF and I'm starting to lose water regularly.im thinking worse case scenario I.E head gasket.firstlybhow much would is it likely to cost to fix.alternatively any ideas on what else I can check.regards in advance Tony |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
Look for Oil in Water Fill Reservoir &/or Mayonnaise in Oil Filler/Cap.... |
Checked those 2 and they are okay,in that the oil cap is clear.no gunk on the cap none on the dipstick.no leak I think on the water tank? I'm at a bit of a loss.any ideas on rough cost of head gasket? Again cheers tony |
If no signs in Oil or Water then is very unlikely to be Head Gasket. Much more likely a slow leak in the Radiator that is evaporating. |
Many thanks for your replies .im putting it into an Indy on Monday morning .im pleased it doesn't look as if its head gasket related.should be able to go on another holiday.again many thanks.will keep you all informed as to what it was .hopefully.regards tony |
| paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222
Or a 'leak' on the inlet manifold gaskets - that's a likely a place as any, sometimes you can see a few drops of condensed coolant on the pan, or staining is a sure sign. The leak is so small it comes out like steam....sometimes you can smell it, another sure sign.
| Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267
I'd check for the water pump.
Many thanks for your replies gentlemen.ive checked the water level this morning and only lost a tiny bit.i
Hi guys,having had the engine pressure tested ,I've been given bad news.just 220 miles short of the 100,000 mileage marker looks like its the head gasket.ive been told a grand to fix.im in Southampton ,does anyone know anyone who can fix them and also the likely cost .is a £1000 about right . Regards in advance .tony |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Hmmm, bad news Tony, sorry to hear that, not a normal thing for the 4.4 V8. If you have an Indie already suggest you use them. Most of the cost is in labour, it is probably quite involved getting to the head gaskets. Maybe ask for a cost breakdown, and perhaps someone can give an indication of the LR hours for the job.
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
did they only do a presure test? You should also get a sniff test done before you commit to a HG replacement. £1000 is very cheap. I know a friend had his done and it was just short of £2k. What's the pressure liked in the top hose? That's normally a sure sign of HGF. There are loads of areas for the 4.4 to lose water. Most are hard to see our notice at first. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
I agree with Rob, don't despair yet. Have a look for the other tell tale signs, white sludge, water in the oil, gas bubbles in the expansion tank (smell as well), water vapour from the exhaust, pressure in hoses etc.
^+1 I still don't think its HG. |
Don't worry and don't let the issue get to you. The 4.4 system is a bitch and only gets worse with age. I would guess you have a leak at the front of the engine. Rad, water pump, hose and the lack is being blown over a warm engine resulting in no signs of fluid. Do you have LPG? The coolant house of the rear manifold is prone to leaking. a |
| All times are GMT |
